Question about Refrigerators
Frigidaire gallery model plhs267Za
I have a frigdaire gallery model plhs267Za side by side fridge, I came home from work today and everything in the freezer has defrosted, it is making a buzzing sound on and off.... can you help me? would it be the compressor? thank you for your time
  • Anonymous Mar 23, 2014
    Auto defrost
  • 828 Answers
It sure sounds like a compressor problem to me. The buzzing sound is the compressor trying to start followed by a click which would be the overload protector tripping.
Posted on May 30, 2008
PLHS267ZA is leaking water from the bottom (freezer side)
I would look under the fridge for a drip pan that might be full, so when it defrost it overflows the pan and runs on the floor. If not that you must have a blockage somewhere in the drain line that runs to the drip pan. Take out the shelves and take off the plastic panels to access the drain and drain line, pour some warm water down the drain to unplug it.
Jan 03, 2014 | Frigidaire PLHS267ZA Side by Side...
My 15 month old frigidaire gallery just died totally today without warning. power outlet is ok . any ideas as the warranty is out model #4A11007114..
Change out the defrost control and cold/temp controls.
See a similar schematic at:
http://www.partselect.com/Schematics/Frigidaire/ZLHFL7NU.gif
Jan 16, 2013 | Frigidaire Gallery GLHS66EJ Side by Side...
I have a frigidaire gallery side by side and the bottom cooling coils inside the freezer are frosting up. It is not ice, just looks like snow. What should I do to fix the problem, it's not freezing or...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 16, 2010 | Frigidaire PLHS267ZA Side by Side...
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a frigidaire gallery model plhs267Za side by side fridge, I came home today and everything in the freezer has defrosted, it is making a strange buzzing sound on and off.. can anyone help? thank you
I THINK THE BUZZING IS THE COMPRESSOR TRYING TO START,ALSO LOOK ON THE BACK OF FREEZER AND SEE IF THE WALL HAS FROST ON IT,IF IT DOES YOU HAVE A BAD DEFROST HEATER OR TERMINATOR OR IT IS STUCK IN DEFROST,LET ME KNOW WHAT YOU KIND,ALSO YOU SHOULD UNPLUG IF YOU FIND THE COMPRESSOR IS TRYING TO START BUT WILL NOT,PULL OUT FRIG. AND SEE IF YOU HEAR THE CLICKING SOUND,ALSO PUT HAND ON COMP. TO FEEL IF RUNNING,BECAREFUL MIGHT BE HOT
May 30, 2008 | Frigidaire Refrigerators
Did you leave the door open? check the light socket for shorts ..check the door switch the light will go off when to door is closed..
May 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Refrigerators Logo
411 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
