Question about GE Washing Machines
When water temperature knob is set to cold, warm/cold or hot/cold, only the hot water comes out. I have removed the cold water hose to ensure there is not a clog and the water flows through indicating there is not. Also, I checked the hook-up faucet and the cold water comes out okay. What other options do you suggest that I can check.
  • GE Master
  • 8,220 Answers
Your water temp switch may be faulty.
Posted on Oct 08, 2010
Water is cold regardless of the setting
I would check the water tempeture knob with a multimeter, u did check the water outlet hoses to see u are getting hot and cold water from them? Also if ur water inlet valve is bad it may only allow cold water or only hot water?
Feb 26, 2015 | Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
No hot water
Make sure your hot water supply valve is on first. If so then try reversing the hot and cold water feed lines and see if you get hot water when asking for cold. The water valve for the hot water side could be bad. Are you familiar with a voltage meter or know someone that can see if you valve coil is getting 120V when the machine is trying to fill with hot water. If not the control unit is faulty. If you do have the 120Vac on the solinoid coil and no water the either the coil is open circuit(bad) or the inlet is plugged. Most generally the problem is in the control knob unit.
Feb 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Hot/Cold water knob will not work on washing machine
Does the water flow when you have it on warm or cold settings?  If on warm setting and water flow is cold, its probably the mixing valve.  This part isnt that expensive, and not that hard to replace.  Remove the two front console caps, remove the two console hold down screws then flip the console out and then over the top.  You will see two gold cabinet hold down clamps, pop them out, the lift the whole cabinet off the unit.   You will see the mixing valve right where the inlet hoses connect to the machine.  Let me know if you need further help.
Oct 16, 2007 | Washing Machines
Washing Machines Logo
64 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
