Question about Hobart Dishwashers
Calad@hI have an Hobart 9T2, the heater 240v contact switch is defective. There is no number on the part.
  • orcalad Oct 09, 2010
    The is there are no numbers on the contactor, I was hoping for the specific number. Grainger should be able to help. Thanks
  • Hobart Master
  • 43,501 Answers
All you need to know is tha coil voltage....that will be on the side of the round coil under the contacts... it is probably 240v... then if there are two or three contacts... and the amp draw of the heater coils...that will be on the nameplate....
Then go over to www.grainger.com and order a matching general purpose contactor from them... they will get it to you in a couple of days...
heatman101
Posted on Oct 09, 2010
Trying to find the age of a Hobart Mixer serial number 1569386
Contact hobart directly, they tend to keep a record of machines, and would probably be able to as sit you
Feb 15, 2018 | Hobart Food Mixers
What is a good source for a reasonably priced 200-240V 2.7 HP switched reluctance motor found on Hobart's HL600 mixers?
Baldor no longer manufactures that motor. Hobart would have to install a kit that includes every electrical component in the machine. Be careful if you find a used one, they have a very fragile encoder on the rear of the motor.
Aug 19, 2015 | Hobart Food Mixers
Can I rewire a Hobart VCM-25 Mixer/Cutter 460v to run on 220/240v?
There is likely a nameplate with a wiring diagram inside. Without being familiar with the specific model, I can't tell you where. If you can find it, it will show both 460 and 230 volt configurations. Regardless, you will find inside the wiring box (where the conduit comes into the mixer) there are four wires corresponding to two windings - for 460 volts, the windings are wired in series. For 230 volts, they should be wired in parallel.
Jul 16, 2014 | Hobart Food Mixers
Hi, my Hobart D300T is making a really loud buzzing sound on start up, pls help
Could be a problem with the start windings.or start switch.maybe a capacitor .on the older models the start switch sticks just needs freed up and contacts on start switch cleaned.
Apr 15, 2011 | Hobart D300 Stand Mixer
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
Good morning, I have 01 Hobart dishwasher AM14, i need to be replace rinse sensor probe and temperature sensor for booster heater.But I can't to find Hobart part number Please help me.Thank you.
294692 for the rinse probe.
"temperature sensor for booster heater"? Do you mean the thermostat? If so, part number is 274161.
Parts breakdowns and part numbers are available at www.hobartservice.com. Click "Parts" on the left, then click "Hobart SmartParts System" on the next page. You'll be asked a series of questions to identify your piece of equipment, and then you'll get a parts list and have links to parts breakdowns for various sections of the machine.
Nov 20, 2010 | Hobart AM14C-155 Dishwasher
My EH40 is not supplying power to the water heater. I hooked the power line in to posts 1 and 2 and I hooked the load out to posts 4 and 6. When I use my power checker it reads no power to posts 3,4,5,...
I have an EH 40 sitting in front of me right now.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
The link above shows correct 240V water heater timer wiring for EH40
Link below shows an overview picture of EH 40 connected to 240V water heater
http://waterheatertimer.org/images/EH40-water-heater-circuit-5.jpg
http://waterheatertimer.org/240-v-water-heater-circuit.html
EH40 has a 240V clock.
Terminals 1 and 2 send power to the 240V clock
Power to the clock terminals do not pass through timer to any other terminal
How to wire EH40 for 240V
240V line has 2 hot wires from breaker box.
Lets call these wires Hot1 and Hot2
These wire are interchangeable on 240V circuit
Hot1 connects to terminal 1 with a jumper to terminal 3 (or connect to 3 and jumper to 1)
Hot2 connects to terminal 2 with a jumper to terminal 5 (or connect to 5 and jumper to 2)
240V circuit has 2 wires going to the Load
Let's call these Load1 and Load2
These wires are interchangeable on 240V circuit
Load1 connects to terminal 4
Load2 connects to terminal 6
If the timer is still not working, go back to the breaker and test if it is delivering 240V to the circuit.
If breaker is bad on one leg, then the circuit can test with live power, but the 240V appliance will not work.
240V circuit requires both legs of 240V before circuit is complete.
Oct 24, 2010 | Intermatic EH40 - Electronic Water Heater...
I want to install a timer on a 240v wall heater. Do I intercept just one leg?
Hi and welcome to FixYa,
The short answer is yes. A few other ideas you may want to consider:
  • current capacity of the contacts of the timer switch (relay);
  • terminals should be screw type, not soldered nor plug-in;
  • preferably switch the Line 1 (the hot wire);
  • for safety reasons, separate fuses for the timer circuitry as well as the load (heater).
Good luck and thank you for using FixYa.
Feb 23, 2009 | Fahrenheat Electric Hydronic Baseboard...
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Hobart HEC40 208V to a 240V source
The only difference should be the elements. Consider installing a buck-boost transformer. It may be cheaper.
The Hobart part number for the 240 volt element assembly is --
# 342170-00002. Your local Hobart can get you a price.
Mar 08, 2008 | Hobart HEC501-208V Electric Single Oven
Dishwashers Logo
114 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
