Question about Whirlpool Duet GHW9150P Front Load Washer
MACHINE STOPS RIGHT AT RINSE AND SPIN CYCLE. DIGITAL READING SAYS 21-F OR 5-D.
  • Whirlpool Master
  • 2,180 Answers
Unplug the washer,remove the bottom panel,with a shop vac,vac out all the water in the tub,next put down some towels on the floor and around the pump and have the shop vac ready,unscrew the middle part of the pump just enough to have water draining out and vac it up as it's coming out with your vac,when all the water is drained remove the middle part of the pump and clean it out,don't get surprized from what you're gonna find in there and the water is gonna be stinky.put the pump back together,add some water to the washer and then hit spin,you should hear the water draining out,if it doesn't you still have something in the pump or you killed the pump and need to change out the pump with a new one,also check the hose that connects to the pump,stuff gets stuck in the hose,you should be fine,let me know what you find in there and how you make out
Posted on Oct 08, 2010
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Why my washing machine will start the wash cycle but will not spin or rinse?
    the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
    Aug 17, 2014 | Fisher and Paykel Washing Machines
    Nec nw-891 washing machine will not complete the programmed cycle
    Apparent malfunction in the timer circuits. Specific Component replacement not available.
    Jun 30, 2009 | Washing Machines
    Washing machine wil not fill - tries several times then stops and all lights except 4 go out
    That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
    Apr 14, 2009 | Washing Machines
    Washing machine won't rinse or spin
    sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
    Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore HE2plus wont spin...F-21 error
    Apparantly the F21 error means there is a drain problem...I removed the drain hose from the output in the wall and held it down at ground level and let it drain into a pot...I ran the rinse, drain and spin cycle while I did this but before I hit the start button I hit the 2nd rinse button to turn off the rinse portion of the cycle. It seems to be draining fine now.
    Jul 01, 2008 | Washing Machines
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Bosch WFL 2860 Stops Part Way through Its Cycle
    When a machine stops during its rinse period, it is normally a block in your outlet filter. And you say it has not been maintained in any way for 5 years; at least you shd be doing the minimum maintainance like clearing your outlet filter.
    Front bottom right, is where access to the filter normally is; get to it and clean out, plug off the wall first. The large plastic is to be turned anti-clockwise to remove, refit carefully after cleaning.
    Nov 25, 2007 | Washing Machines
    Whirlpool Duet GHW9150P Front Load Washer Logo
    366 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
