Drivers for bjc250 printer to run on windows vista
  • Anonymous Apr 08, 2009
    it does not support vista
  • 550 Answers
[quote=Canon Knowlegebase]
This product can be used with Windows Vista.
Since the printer driver for this product is pre-installed in Windows Vista, you can use this product only by connecting it to a Windows Vista computer.
To install the printer, select Start, choose Control Panel and select Printers. Now select the "Add a Printer" option and follow the on-screen instructions to install your printer. [/quote]
Very long Canon link will def. wrap
http://www.canon.ca/product_reg.asp?lng=en&pid=16&pname=BJC+250+series&pr=0&shlink=http%3A%2F%2Fcanoncanada%2Ecusthelp%2Ecom%2Fcgi%2Dbin%2Fcanoncanada%2Ecfg%2Fphp%2Fenduser%2Fstd%5Falp%2Ephp%3Fp%5Fli%3D%26p%5Fpage%3D1%26p%5Fprods%3D9%2C45%26p%5Fpv%3D2%2E45%26p%5Fcats%3D0%26p%5Fsearch%5Ftext%3D%26p%5Fnew%5Fsearch%3D1%26p%5Fsearch%5Ftype%3Ddflt%26p%5Fsort%5Fby%3Ddflt
Posted on May 30, 2008
Cannot get a driver to load off line. 64 bit windows7 no disk
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 964 Photo All-In-One Printer owners thread (W7)
Rick
Aug 14, 2011 | Dell Photo 964 All-In-One InkJet Printer
I have a dell printer A920 and an acer computer with windows 7. Having trouble getting the printer to work
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download and install the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Dell A920 All-In-One Inkjet Printer owners thread (W7)
Virus programs and firewalls will block communications.
Rick
Apr 18, 2011 | Dell A920 InkJet Printer
I just upgraded my computor windows 7. And it deleted my epson 1280 printer. How do get it back. wmizikar@zoominternet.net
Some older printers don't have a driver (software that tells the PC how to work the printer) for Windows 7. This website is Epson's Support site, and lists a driver that it says is "compatible" with windows vista.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?cookies=no&oid=14387&infoType=Downloads
sometimes Vista drivers will work with Windows 7, but not always. Choose either the 32-bit driver for Vista, or the 64-bit driver for vista, depending on which edition of Windows 7 you are using.
If that doesn't work, then you unfortunately either need a new printer, or you need to hook that printer up to a computer that is running Windows vista or older.
Apr 04, 2011 | Epson Office Equipment & Supplies
Lexmark 5400 series model no X5470 is not working with windows 7 ultimate . please give me a solution Amresh Mishra
First, unplug the Lexmark printer from your computer. Then uninstall any existing Lexmark X5470 driver from your computer. Go to Start menu -> Programs -> Lexmark X5400 Series -> Tools -> Uninstall. Uninstall the driver. Reboot pc when prompted.
When your computer turns on, check if your Windows 7 is running on 32-bit or 64-bit service type. Go to Start menu -> right-click on Computer -> Properties. Take note of the Service Type.
Visit the Lexmark website to download the Vista driver. Use the links below:
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Dec 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
INSTALLATION OF LEXMARK X5250 PRINTER ON WINDOWS 7
Hi, Lexmark printer drivers can be found on this site: Driver Update Software for XP Vista 7 8. Have a nice day
Thomas
Apr 09, 2010 | Lexmark X5250 All-In-One InkJet Printer
I cant get my Lexmark all in one x5150 to download to my HP vista computer ,pls help me
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
ps. if no vista drivers are available then your only option is to use general drivers that came with vista or contact lexmark and request drivers for the printer.
Mar 04, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer won't print
Although Lexmark has not released a Windows Vista driver for the Lexmark X75 printer, there is a good chance that Vista will support your printer without the need for installing a driver (i.e. Windows Vista probably comes with a driver for your printer already built into the operating system). Windows Vista comes with support for 2.2 million devices and since your printer is not a new model, it is likely to be supported. Just try connecting it to a computer that is running Windows Vista and see if it is detected and installed for you.
We do have the drivers for Windows 2000 and Windows XP available for download from our driver database:
Lexmark X75 Printer Driver
Jan 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Driver for BJC-250 for Vista
I made it work on windows vista x64 and x32! Dont know on windows 7 but think it will though.
Just enter control panel in windows vista, locate "printer", double click it and inside you will se a "link" under the adress bar named "Add printer" enter it and a wizard should pop up, choose "Add a Local printer" --> "use existing port" I chose "LPT1" ---> locate the model and choose : Canon BJC 30, (Canon Bubble Jet 30). and after the wizard have installed you might be able to print.
Jun 09, 2008 | Office Equipment & Supplies
NEED TO HAVE INSTALL SOFTWARE FOR wINDOWS VISTA
Join the Alps mailing list at YahooGroups. The drivers are in the files section.
http://tech.groups.yahoo.com/group/Alps/
Apr 08, 2008 | Alps MD 1000 Thermal Printer
My HP Printer Deskjet 3320 is not working with Windows Vista
You can follow Hp's Installing and Configuring an Alternate Driver in Windows Vista. Click this link provided by HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808478&lc=en&cc=us&lang=en&dlc=en&product=75035
Before you follow though with Hp's alternet driver site. Please run windows update for Vista un till no updates are left. If your printer still fails to run correctly than try HP's alternate drive.
Good luck & kind regaurds..
Mar 08, 2008 | HP DeskJet 3320 InkJet Printer
119 people viewed this question
jasbo
jasbo
