Question about Meade ETX-90EC (325 x 90mm) Telescope
Secondary miror glue spots.What can I do? - Meade ETX-90EC (325 x 90mm) Telescope
    Novelist:
    Champion:
  • 227 Answers
Gently use pure acetone (no perfume or dye) on a q-tip. just dampen the q-tip and only use one stroke per q-tip do not use any pressure as this will damage the mirror surface Use distilled water to rinse mirror. LET AIR DRY!
Posted on Oct 09, 2010
I have some spots of superglue on a lovely shirt, is there a substance which will remove it?
Probably not without damaging the fabric because these glues are so hard. 2 products I would try if you can get them where you are:
1. tea tree oil
2. Eucalyptus oil.
These will react with normal glues and break them down without harming the fabric or taking out any colour. I have not tried either of them with any of the super glues so I cannot say if it will be successful with such super tough products. I would also test them on another piece of similar fabric spotted with the glue before using them and that will tell you if they will work on the SG.
Other than that you would need to try various strong solvents to see if they would break down the glue and enable you to remove it. The problem is you may end up with a stain, loss of colour or some damage to the fabric if it is a sensitive fabric. If you test some of these on an old piece of similar fabric you have spotted with the glue you will be able to see which one worked without harming the fabric.
If you can buy a bottle of dry cleaning fluid (I cannot remember the technical name) you may be able to move it using a liberal amount of that product or just soaking the areas with the spots in the fluid. Be careful handling it as it is pretty toxic.
Applying steam (from a boiling kettle ) to areas of the fabric affected may soften the glue a little and enable you to roll it off the fabric if it is not heavily impregnated. Whilst this can work with some of the softer glues it may not with the SG. I would also test it first on another piece of fabric
Jan 11, 2016 | Scotch Super Glue Liquid Plus, .07oz,...
Dropped a glob of Gorilla Glue on laminate flooring. Dried. Haven't tried to remove it yet.
The "normal" response would be to use acetone which is a solvent for gorilla glue (or super glue), but acetone will dissolve the material used to laminate the floor and cause it to become cloudy. I've had success scraping globs of glue off with a fingernail. Better yet, try putting an ice cube over the spot of glue until it gets brittle, and you should be able to scrape it off. Hope this works! Good luck!
Apr 24, 2015 | Building Materials
Audi a3 black edition head liner has a small cigarette burn
Youre going to need a razor blade and some super glue. Take the razor blade and SCRAPE some fuzz from an inconspicuous spot of the headliner(maybe under a trim piece or light bezel) apply a small amount of glue to the burn, Then after you apply the glue, take the fuzz that you accumulated and apply to the glue. Lightly.
Feb 03, 2013 | Cars & Trucks
When viewing venus or other stars there a black spot in the center of the object. It appears to be the 2nd mirror refleting to the main miror. what have I done incorrect?
You are NOT in focus. Turn the focus knob a little until you see a perfect "disk" for the planet. Stars are always POINTS of light, with a telescope or without a telescope.
Aug 28, 2010 | Celestron NexStar 114GT (269 x 114mm)...
(4) Light Tunnel Mirrors Came Apart
i will email you piks u need to use high temp sealer
May 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
No miror print in any programe
After you click print a new window opens, click on printer preferences where you choose paper size and orientation, etc. open the different tabs at the top until you find mirror image printing, don't forget to set it back cuz all will be in mirror...
Sep 10, 2009 | Canon LASER SHOT LBP-5000 Printer
I have dust spots on screen and is not from lamp miror or screen there for must be from the tubes or lens. how doy you get access to them. thank jose ps. samsung sp43j6hd
they might b come from nywhere so open it and wipe the dust and then close it carefully and use a phone cover to get rid from this
Aug 22, 2009 | Samsung SCH-i600
I need directions on installing a 2000 pontiac grand am driver side mirror
pull out the small speaker out bt gentle dont brake the frame and take nut holder nut out with socket or wrench and pull the miror out slowy till see the connector come out ..disconnect ..connect the new miror cable and with the miror togethar and screw back and ready to go..
Jun 04, 2009 | 2000 Pontiac Grand Am GT
The seal of the dishwasher is broken and the spot welding on the stainless steel strip that holds the seal has pulled away from the tub.
use super glue to glue in place in spots cut away seal near the weld seams, then make sure the door closes ok then get 5 minute epoxy and glue the seal on where it comes off, it's a permanent fix for a old machine but it will work. so go ahead and replace the seal.
May 29, 2009 | Dishwashers
Meade ETX-90EC (325 x 90mm) Telescope Logo
62 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
