Question about Viking Dishwashers
No lights on program buttons. when turned on the water gushes in.nothing else works. can not program.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the drain hose for any clogs and try to clean the hose and the drain pump filter. If the issue is still not resolved then the electronic control has gone bad and should be replaced. However, before replacing the control you can try to take it apart and blow some air with the help of hair dryer on the control so that if there is any moisture, this blows it off. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
Single mother of four wash machine not working only 2 yrs old.
Take off electricity wire, Open the filter from the front( maybee need to remove a rectangular cover.) turn the filter anti-clockwise. take out the hairneedle or coin. (the water will come out from the filter so make preparation with towels., see inside the filter if something is stucked around the small propellar. Turn the electricity back on. choose for example pumping program or centrifugeprogram. After that the machine should work.
Jun 01, 2013 | Whirlpool Washing Machines
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
Cannot turn off flashing lights on buttons to start espresso
The keypad needs to be programed. Depending on your model there will be a small toggle switch on the right side, just behind the connection of the hot water valve(you will have to remove the top panel). Move the switch to the left, then press the program button at which time all the lights will be lit. Using a measuring cup press a button you want to program until you get the desired amount, then press the stop button(when programed the light will turn off), repeat to program the other 3 buttons. When done program move the toggle switch to the right. If the machine does not hold the program then the flowmeter under the drain tray(silver box with 3 wires on top), is damaged. Either repalce the top or check the impeller in the flowmeter, the magnets might dirty.(Make sure water is turned off before openning the flowmeter.
May 28, 2009 | Astoria Argenta SAE/JUN Espresso Machine
GE WCVH6260 stops unexpectantly
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Nov 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
My GWL11 won't fill correctly or wash!
Hi there you need a new cold valve in the washing machine. :)
Sep 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
148 people viewed this question
Top Viking Dishwashers Experts
Mike
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
