Question about iRobot Roomba 560 Robotic Vacuum
My roomba 560 approaches the dock and attempts to dock. However, it never seems to align correctly and backs out. This is a continuous process. It simply will not dock at all. Any suggestions?
Check the connector on your ROOMBA, there is a switch that open the ground when you connect the charger direct to the ROOMBA and a lot of times it get stock and remain open. Using a small screwdriver press the metal plates to force to close.
Posted on Oct 26, 2012
  • 1 more comment
  • lalani Oct 30, 2012
    the paid tech guy at irobot could not fix the problem but you did......THANK YOU SOOOOO MUCH....
  • Colin Olds
    Colin Olds Dec 04, 2013
    can you take a picture so i know what im looking for?
  • Carlos Figueiredo Mar 02, 2014
    Did not understand what i should look for too. Connector? Switch?
No suggestions, but my Roomba 530 is doing the same thing.
Hope you find a solution soon.
Posted on Oct 25, 2010
How do I change schedule on Roomba
go to roomba.com when at there site go to customer care support then to pooduct resources then select a robot roomba,scooba,ect find your sereies 700,600 ect go to documents&manuals then to scheduling roomba then to viewing and deleting schedules follow the steps
Dec 18, 2012 | Roomba iRobot 560/561 Vacuum Cleaner...
Roomba stopped after 45 minutes. does not move. manually placed on docking station...nothing
Sounds like something's dead either with the roomba or the charging station or power supply. Does it charge up if you plug the power supply directly into the roomba, instead of into the charging station? If not, you'll probably have to return it to the place you bought it.
Aug 27, 2010 | iRobot Roomba 560 Robotic Vacuum
560 moves away from dock appears lost
hey gsaban
does it sing 9 beep when it stops ?
if it does, you are facing a known issue of bumper sensor fail.
See this page and other 9 beep threads on FixYa
have fun
Avi
Mar 12, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 560 won't run correctly
Hey
if it's 5 beeps it says: Drive wheel is stuck
You should clean both , push both in and out and confirm it turns freely
Good luck
Avi
Feb 24, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 560: it only spins in one place, then stops & doesn't dock either.
If there's no message its probably a sensor malfunctioning. It might be a cliff sensor, the bump switch, or wheel-drop (left, right, or caster). Try cleaning the sensors and vacuuming things out as a first step.
Nov 22, 2009 | iRobot Roomba 560 Robotic Vacuum
Our roomba 560 wont charge have replaced the battery Tested the charing unit with another roomba that all seems ok put the uncharged battery into another Roomba but im guessing it now has a memory as this...
Try cleaning the battery contacts with a little rubbing alcohol or contact cleaner on a foam swab, or a bit of paper towel. Take a litle time, it doesn't always dissolve instantly. (Don't use a pink pencil eraser, it would scrub off the plating that prevents corrosion) Clean both contacts on the battery pack and both of the contacts in the Roomba. Make sure the battery is oriented correctly when you put it back in. Also clean the charging base contacts and the corresponding contacts on the Roomba itself.
I'm not sure entirely sure what you're trying to recover - the new battery pack, the old battery pack, or the Roomba itself - but since you can swap parts back and forth, you can clearly isolate the problem. The old battery pack might be rehabilitatted if you have the equipment to recondition it, but if it may not work. The new battery shouldn't have been harmed that easily.
Oct 25, 2009 | iRobot Roomba 560 Robotic Vacuum
My Roomba 560 does not automatically dock as advertised either..
You may not believe this, but the new 500 series lighthouse virtual walls have both infrared and radio frequency communication. How they work and associate with the Roomba is pretty complicated. The best posting I've ever seen about how they work is here:
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=11048
Check out that link to understand how the communication works.
If your Roomba is contained by the virtual walls, then you can assume the IR sensor on your Roomba us good....you should test that though. Then you might have to replace the "home base" which could have a bad IR transponder . New ones can be found for reasonable price at www.RoboticVacParts.com or you could order straight from iRobot for twice the price.
If the Roomba is not contained by the virtual walls, then the IR sensor on the Roomba is likely bad and you'll need to change the bumper on your Roomba. Again ....parts are available through ebay, or www.RoboticVacParts.com. Follow this link if you need it.
http://cgi.ebay.com/NEW-Roomba-500-series-white-bumper-510-530-532_W0QQitemZ270400281066QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef51cd9ea&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Jun 18, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba 560, the small red light above the schedule button will not reset and the roomba will not run. The problem started when I the roomba sat dead for 12 hours. I tried the spot dock reset trick with no...
You should start by removing the "belly plate" of the Roomba and simply removing the battery to cycle power to the unit. If that does not solve the problem, it sounds like you need a replacement circuit board for the 560. That's alot trickier since iRobot doesn't like to sell those...they want you to send to them for service.
Your options would be to send to a reputable Roomba repair center like www.protechrobotics.com or you can buy a replacement PCA from places like www.RoboticVacParts.com and replace yourself.
May 07, 2009 | iRobot Roomba 560 Robotic Vacuum
Open Questions:
See all iRobot Roomba 560 Robotic Vacuum Questions
iRobot Roomba 560 Robotic Vacuum Logo
1,466 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
