Question about Logitech FreePulse Wireless Consumer Headphones
Defect headset my logitect freepulse headset is not connecting to the transmitor...it keeps on showing a solid red light while the transmitor blinks non stop....would be delighted if any1 can show me what to do to fix it...??...help in need...thanks..:)
Hold the transmitter button for about 50sec until it flashes blue/red quickly and connect the headset afterwards. Hope that helps. God bless.
Posted on Jun 15, 2008
My connector is frozen on blinking red and blue. It will not connect with the head phones and go solid blue.
Have you tried doing the same with the headphones? If you hold the power button down on both the transmitter and heaphones (get them both flashing red and blue), they might pair.
Jul 15, 2010 | Logitech FreePulse Wireless Consumer...
My Freepulse headphone won't pair anymore. Both components charge, both both of them display the red LED light. I've tried the override button on the transmitter, and I've tried holding the power button...
You hold the button on the transmitter for about 50 seconds - light flashes red, solid red, goes off and then flashes blue and red. Then you can do the same on the headphones. Then wait and they should pair.
Jun 29, 2010 | Logitech FreePulse Wireless Consumer...
My motorola h721 keeps blinking red.
if you didn't pair your phone up yet, that could be why. Hold all 3 buttons down for 10 sec. should go solid blue, then pair your phone cause its in discovery.
Aug 15, 2009 | Motorola Mobility H710 Bluetooth Headset
Still froze
Does the light blink blue other wise and show red when charging ?
Make sure ear set is fully charged overnite?
Turn off and turn on.
Only then when turning on, DONT REMOVE YOUR FINGERS AND KEEP PRESSED for about 10-30 Seconds,, Watch for SOLID BLUE... Remove and proceed to pair..
If it still does not work, I would suggest that you keep trying .. Since I assume that the phone is charging well and then discharging over a time..
Oct 29, 2008 | Motorola Mobility Logitech Mobile...
I have Logitech wireless headphones for my Ipod, and I can't get them to work. When I press the on button on both pieces, it goes solid red and not blue.
Visit the Logitech support website and find the instructions to reset and pair them. Since yours is for an Ipod I'm assuming you have the older white/grey model and not the freepulse headphones. The procedure is not the same. From memory the procedure it to reset both (look for the small hole to insert a paperclip). Once both are reset begin with the transmitter. Hold the power button down for about 30 seconds until the light flashes red and blue. When it does do the same for the button of the headphone until it flashes red and blue. When both are flashing red and blue they should pair together and the lights should turn solid blue..
Oct 15, 2008 | Logitech FreePulse Wireless Consumer...
My logitech headphones dont turn on anymore.
Quote from LOGITECH official site:
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Do this and Freepulse will be pleased.
Aug 15, 2008 | Logitech FreePulse Wireless Consumer...
H670 bluetooth not working
try adding headset, select blue T. device the properties, services and check headset and apply
Apr 26, 2008 | Motorola Mobility H670 Wireless Headset
Logitech wireless headphones problem
just hold the button down until it begins to flash red. when u power on the headset it should flash red/blue then both will turn solid blue when they are synced. Hope this helps.
Apr 05, 2008 | Logitech FreePulse Wireless Consumer...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Logitech FreePulse Wireless  Consumer Headphones Logo
184 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
