Question about Aiwa HV-MX100 VHS VCR
I have aiwa multi system vhs player model hv-mx1 recently tapes are getting stuck inside tecnician said its the loading sensor that is malfunctioning were can i find one ? and my second qwestion is once this vcr is repaird since i have close to 100 pal system vhs recordings of family how do i tranfer tham into a dvd thanks in advance for answering gil ben-kely phone number is 2012807433
3 Suggested Answers
  • 120 Answers
SOURCE: AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Posted on Jan 15, 2009
nfandres
  • 168 Answers
SOURCE: No Color
did u try cleaning the video head? heres how! unplugged the unit. open the cover. get a piece of clean white paper. put a little alcohol on it. place your finger on the paper and slowly touch the head but not too much force then gadually move the drum back and forth. donot move your finger up or down. just clean it horizontally by slowly moving the drum leaving your finger stationary. let it dry and test. if the problem persist see a doctor(technician), u have a problem with the color circuits. good luck!
Posted on Feb 03, 2007
Will Aiwa HV-MX1 Playback Extended Play (EP) Speed?
Probably not then, but you could try a tape recorded at EP.
Jan 05, 2013 | Aiwa HV-MX1 VHS VCR
Tape an catridge stuck
Unfortunately, the best chance you got of getting the tape out is to open up the video to release the tape.
Feb 08, 2008 | Aiwa HV-MX1 VHS VCR
Starts to play a tape then shuts down
Hello
Video casette is not moving normally. It struks at the take up spool. Check the belts. OK.
Feb 12, 2011 | Aiwa HV-MX1 VHS VCR
Aiwa HV-MX1: tape won't eject from VCR and it switches off.
Turn over the VCR. Unscrew the base. You will see the 3 belts. Turn the rightmost belt clockwise or anticlockwise (don't remember) but you will see the tape hold mechanism moving down. Once it is all the way down, you can eject the tape out.
You may need to replace one or all 3 belts. This is being caused by belts being loose.
hope this helps.
Sep 22, 2009 | Aiwa HV-MX1 VHS VCR
Jan 15, 2009 | Aiwa HV-MX1 VHS VCR
Picture gets bad after playing a while
Just the usual problem of needing the rubber belts replaced.
They last about 6 years normally so you are overdue.
Buy a kit of belts for your model from all kinds of sites on the net and install them yourself if you are handy with delicate mechanisms.
Hope ya fix it!
Jan 14, 2008 | Aiwa HV-MX1 VHS VCR
Tape stuck in VCR
more than likely one of the belts has broken
Oct 12, 2007 | Aiwa HV-MX1 VHS VCR
No Color
Jan 31, 2007 | Aiwa HV-MX1 VHS VCR
Aiwa HV-MX100 VHS VCR Logo
148 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
