Question about Infinity Overture 3 Speaker
I have Infinty Overture 3 speakers. Earlier this summer, my house was struck by lightning and thats when it started... Long story short, just bought a new amp and hooked it all up only to have the same issue. No bass through the woofers on the speaker. This speaker has a powered amp for the woofers. Midrange and tweeters working fine. My BU1 subwoofer is having the same issue... also powered. I have hooked them up to other amps that are working properly, and still no luck. I cannot get bass even though the LEDs are all showing that the amps are working. I have checked, rechecked fuses and connections. Help
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Posted on Apr 15, 2007
SOURCE: bypassing the 150 watt blown amp with passive crossover
3/4 update: i bypassed the 300w amp on my first ovtr3 with a cs3006 crossover i purchased on ebay. the input wires at the base of the speaker were connected to the input of the crossover, the bass output of the new crossover was connected to the yellow/yellow-black lf+/lf- wires that used to leave the old 300w amp. the high freq output of the new crossover was directly connected to the leads coming from the speaker's tweeter (running the midfreq outputs from the new crossover to the input of the speaker's old crossover is no good, since the midfreq output of the new crossover would rolloff and provide little high freq to the tweeter). The mid-freq output from the crossover was connected to the input of the old crossover that came with the speaker (alternatively, i could have wired the mid freq output from the new crossover directly to the midrange speakers, but i figured the old crossover might have had some characteristics that would have been helpful. the result is better than i hoped for! true, the bass is not quite as floor shaking as before (and you need an amp that can boost +5-+10db below 350Hz and rolloff the boost above 350Hz), but the end result is more than satisfying and gives these speakers new life. I am using a Sony receiver that puts out around 200W for the front speakers.
Posted on Mar 04, 2008
TJBENGR
  • 121 Answers
SOURCE: Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and resisters...cheap)). If it is close to 4 ohms check the wiring and connectors..to and at the speakers, most likly the receiver/amp is not blown.
Posted on Apr 20, 2008
SOURCE: i have a set of cerwin vega ls-12 3way woofer works but tweeters
thanks for replying so fast "oilcitycompu", i will do that .will let you know if it worked , thanks
Posted on May 23, 2009
How do I fix a 50 Plasma TV that seems was struck by lightning
Your probably have power supply damage, but lightning strikes can do major damage in all circuits.
Aug 07, 2015 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
House struck by lightning and no picture in tv
I am so sorry but you should have claimed that on insurance. The amount of damage to all the solid state items in that set would mean that you are going to be replacing everything.
Dec 10, 2013 | Panasonic TH-50PX75U Plasma HDTV
Controller not working
The rinnai is a computer that heats water. It is not ordinary water heater most people are familiar with, and repairs are not do-it-yourself, requiring a trained technician qualified in that brand who can diagnose both computer and water heater problems and plumbing problems.
Call rinnai for recommended local technician. Click on support tab. Note their webpage is very short on repair details, unlike companies that sell tank-type heaters... because tankless units are not do-it-yourself.
http://www.rinnai.us/tankless-water-heater
Problem might be simple blown glass fuse on circuit board or complete failure of computer and sensors.
Here is page written for Rheem tankless, that explains general complexity of tankless computers, and showing required maintenance, such as deliming each year:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
To save problems with tankless computers plus anticipated expense of maintenance and repairs, I recommend homeowner install tank-type gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Also install one-time-use whole house surge protector, and install grounding rods to prevent further damage... lightning frequently likes the same places over and again:
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Gene
h
Aug 12, 2013 | Rinnai Water Heaters
Nothing works.
Remote receiver got fried by the voltage spike. If you have pull chain controls as well, you can remove the receiver and possibly be able to save the fan, but the capacitors, may have also been fried. If the capacitors are fried, then most likely the motor experienced some seriously high voltage too, which would mean I would replace the fan. I assume you have had the house's wiring inspected? If lightning struck the house and killed the fan, then it likely ALSO damaged other electrical components. If the lightning struck your power transformer and not your home directly, you may can get the power company to pay for this ceiling fan as the transformer is supposed to have a lightning arrester on it.
Mar 31, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
AC won't cool
you would be surprised what lightning can do if its documented on a service ticket insurance will pay. usually the tell tail signs of a lightning strike wire connections look like welding splatter. have compressor changed and both coils cleaned. Tom
Jun 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Maytag drier model MDE5806AYW
hi thanks for the question i would guess the motor but man thats a hard one if the dryer was hit by lightning it could have caused a fef problems myself i would call my insurance company tell them you were hit before you call the insurance check all appliances in your house you may find other problems thanks the appliance doc
Jul 22, 2008 | Maytag PYE2300AY Electric Dryer
Bypassing the 150 watt blown amp with passive crossover
I'm purchasing 2 infinity 3-way passive crossovers on eBay with the same crossover freqs as my two overture 3's with blown amps. For 19.99 each, it's worth a try. Good luck to you!
Jan 06, 2008 | Infinity Overture 2 Speaker
Infinity Overture 3 Speaker Logo
83 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Matthew Spark
Matthew Spark
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
