Question about Toro Zero Turn 50 In Recycler Kit
How to install a kicker plate to a toro timecutter
2 Suggested Answers
  • 2330 Answers
SOURCE: toro timecutter starter
I think this is going to be like an automotive starter.
You will need to check 3 things.
The ring gear where the starter gear cranks the engine, the starter gear that engages the ring gear, and the overrunning clutch or bendix , which is the springy part that kicks the drive gear into the ring gear.
When you remove the starter from the engine, you will see the drive gear on the end of the starter that was inside the motor.
The drive gear is about the diameter of a half dollar or a silver dollar. it should not be chewed up, it should look like a good gear. Inside the place where the starter attaches, you should see a ring gear, with a flashlight, and those teeth should look good and not chewed up.
On the starter you removed, behind the drive gear and usually inside the starter is the bendix or overrunning clutch , which will push the drive gear into the ring gear when you crank the starter. These parts often fail every few years.
Some people fix them, most people replace the whole starter.
Be blessed.
Posted on May 06, 2013
Why is my toro timecutter wheel squeaking?
Lubrication grease on the axle shaft needs to be replaced or refreshed
Aug 31, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
How do i install a starter cylonoide on a toro timecutter rear engine lawn mower that has a kawasaki 22 hp motor i dont know were the green and blue wires go
do you mean a solenoid? if so then the 2 wires fix to the spade terminals on the solenoid just below where the 2 large red ires are bolted to the solenoid
May 06, 2015 | Toro Garden
How do I replace an idler pulley on mower deck on toro timecutter mx 5060?
Release belt tension, unbolt the pulley, replace it with a new idler pulley. If you need more help, please follow up here.
Jul 29, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
I have a Toro timecutter 4235 and stalls when I try to use the lever
Check with Partstree.com (877-970-2662). They are a big parts supplier out of Austin, Tx. They may have a solution.
Jul 18, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
How to reinstall the main drive belt on a Toro Timecutter 42" zero turn mower.
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual..
Apr 28, 2011 | Toro Garden
Toro Zero Turn 50 In Recycler Kit Logo
121 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
