Question about Technics RS-TR272 Single Cassette Deck
I have a Technics RS-TR180 Dual cassette deck. It has two belts on each deck. One belt has broken and I need a routing diagram to replace it. Can you please help me out?
4 Suggested Answers
SOURCE: Technics RS-TR272 dual cassette deck
My RS-TR272 tape deck plays the cassette but no sound. I have not even used it much, may be 3-4 times in last five years. I tried demagnetizing it but still no effect. It is brand new unit, only thing I did last time was that plugged in the RCA cables in opposite ways one time (Output in In and In into output one). I am not sure if that had any bad effect on it. Can someone please help on this as unit shows cassette playing. There is no volume switch on the unit itself as someone else recommended in the previous answer.
Posted on Nov 25, 2007
caroldon
  • 17129 Answers
SOURCE: How to replace drive belts on Technics dual
First of all you will need some mechanical mind to open out the set. The tape mechanism has to be removed and the connections should be noted and removed. If the old belt is already in the mechansim then you will not have any issue with the direction of the belt to go around the capstan flywheel. If you have alreaddy obtained the correct belt then carefully open the back of the mechanism to remove and reset the new belt. When replacing check for the free running of the capstan if not use a small drop of oil to free. If the belt was not there then wind from the motor to the second flywheel after running it around the first flywheel to drag it along so that when the motor turns you have the flywheels turning freely. reset the back plate using a thin probe type tool to hold the belt and release to the motor. For a first time it may be a bit difficult but try again. Hope you get this right. Good day
Posted on Jul 20, 2010
antoman
SOURCE: tape deck not working on a technics rs-eh600
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
Posted on Oct 11, 2010
Technics rs-tr180 looking for repair manual
Look on Ebay. It will not be available new anymore. I might have it as well for a cost. Visit audioserviceclinic.com. Contact me there.
Sep 16, 2014 | Technics RS-BX501 Dual Cassette Deck
How to replace the capstan belt on a Technics RS-M63 ?
Get the service manual and look at the mechanical drawings of where the belt goes. Most seasoned Technicians just go in and do it. A beginner will have to be more cautious. There are other things in the deck that also need attention like parts oiled and other idlers replaced.
Some Technics decks were ever made to be repaired.
Apr 28, 2014 | Technics RS-TR272 Single Cassette Deck
Thank you very much for your help. Where might I order the belts?
Marrs Communications has most belt kits needed by model number.
Mar 25, 2014 | Technics RS-BX501 Dual Cassette Deck
Technics stereo cassette deck rs az6 spares
Tape belts are universal generally. All you do is measure the diameter of the belt in MM and if it is wider than the "string" type the width in MM again. Put the words "cassette drive belt xx MM" into Google. You don't have to precise with the measurements.
Feb 23, 2014 | Technics Audio Players & Recorders
How to replace drive belts on Technics dual Stereo Cassette Deck RS-TR272 P-K? Thanks desmondali@gmail.com
Jul 18, 2010 | Technics RS-TR272 Single Cassette Deck
Play function won't disengage on Technics dual cassette deck
Remove the cover to see if any belts under the cassette player is cut. Or to see if there are any obstructions.Remove the front cover.which will remove the tape housing of the cassette player. you can check for any broken plastic compoments that might be keeping the housing from opening.Or any belts that may have been cut.
Dec 25, 2008 | Audio Players & Recorders
Technics 373 Dual Cassette - Playback Stops
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
Dec 13, 2008 | Technics RS-TR373 Single Cassette Deck
Technics RS-TR272 Dual - Won't Reverse
Cassette decks that have been sitting for long periods have problems with drive belts and idlers becoming slack or decomposing of the rubber compound. If you wish to keep the unit, please have it cleaned and have belts/idlers replaced with new ones by a professional service. Also have controls and switches cleaned of built up tarnish and mildew to prevent noisey or drop-out audio
May 11, 2008 | Technics RS-TR272 Single Cassette Deck
Technics RS-TR272 Single Cassette Deck Logo
556 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
