Question about Gateway 450S PC Notebook
Display too dim to read
I have a gateway laptop 450s The display is too dim to read. you cannot see anything. I try changing the LCD CONVERTER and the LCD. but the problem still the same. What else do I need to change.
nesley
Need new backlight ??
Posted on May 30, 2008
Sl300 dim
If it is an LCD, there is a back light. That is usually fluorescent so there is an inverter. If it is an LED display, there is no back light as such so no inverter.
All the service manual recommends is to change the DC-DC converter board, followed by the System Board, if that doesn't work the complete display unit.
Helpful blighters at IBM ... not!
Nov 19, 2013 | Lenovo ThinkPad SL300 Notebook - 27384EU
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
I spilled juice on my gateway T-6330U laptop keyboard. I shut if off and pulled the power cord. I noticed it trying to boot up when cleaning it off, the LCD was fadding, and I heard sizzling under the...
Check the video connectors on the motherboard.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 21, 2009 | Gateway T-6330U Notebook
Gateway laptop- screen went dark but is still on.
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 31, 2009 | Gateway 450ROG Notebook
I have a HP Pavilion laptop ze4900. Every time I move th screen, the display either goes off completely, or it goes vey dim and I cannot read anything from it. The only thing I can do to get a display
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Picture flickering with dim display.
May 03, 2009 | Computers & Internet
Cant see anything diplayed on my computer MT3422
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 18, 2009 | Gateway MT3422 RTL Notebook
Dell inspiron 4150 video dim
The empty slot is for a mini-PC card, usually a wireless network card. The 2 wires are actually the antenna wires that connect to the wireless card. The dim LCD may be a problem with the LCD panel display, video controller or motherboard. Try connecting the laptop to an external monitor by connecting to the Video Connector located on the back of the laptop. If the display on the external monitor appears to be normal, then your LCD display panel on the laptop has a problem. If the display on the external monitor is dim then you probably have a bad video controller card or motherboard.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 4150 Notebook
LCD goes dim within 1-2 minutes
You could have a bad "inverter" or flourescent backlight tube, or a problem in your power supply.The only way to isolate the problem is to check each component in sequence.If your hard disk and DVD / CD drive are still working when your screen goes dark, then I'd say it's the "inverter". You'll have to take it to a repair shop.
flipbooks
Jan 20, 2008 | HP Pavilion dv6000z Notebook
Gateway 450S PC Notebook Logo
75 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
