Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Model #919.153231 3 hp...20 gal air compressor runs continuously after building pressure. When new, it would automatically shut off after pressure built up, now it never stops when in use.
  • 520 Answers
Sounds like the pressure switch is faulty. not uncommon on compressors anymore.
Posted on Oct 08, 2010
Compressor runs and sounds ok, but it only manages to show 20 lbs. It will not build air pressure and continues to run.
check air tank drain valve located on bottom of tank, if it is not leaking try adjusting air pres regulator (large black knob close to air hose connection.) the knob when turned in will increase the tank air pressure, if knob wont turn check that lock ring on bottom of knob to make sure it is disengaged. also check for air leaks in all lines and connections
Apr 16, 2012 | Craftsman 1 hp Air Compressor, 4 gal. -...
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I have a Sears horizontal 33 gal compressor Model 919. It will not build up to the required pressure. It does build some, about 20 lbs and goes no higher. I have removed the shroud and can feel a large...
Sounds like part #27 is worn. Replace # 24 24 A 24 B and 24. the cylinder may be worn. Perhaps depending on the age and time and labor replace with new comp. maybe Dewalt.
Feb 17, 2018 | Craftsman 33 gal Air Compressor 6 hp...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Nov 13, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
I have an ingersoll-rand upright compressor model 2545k10-p, 10 hp, 120 gal, 175psi compressor, and the electric motor will run for about 15-20 seconds and then automatically shut off, and be really hot....
Does the motor rotate the compressor or just set there and hum? How old is this unit? Overload heaters may be to small or unit may be single phaseing. Is there air pressure in the tank when this happens.
Oct 15, 2010 | Ingersoll Rand Stationary Air Cooled...
No air pressure
If your motor is running and the pressure is not building it is either the valve plate or the compression ring. Check both for damage.
Sep 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
250 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
