Mitsubishi Model # WD-62725
First, I replaced lamp. Second, replaced 3 bulge caps on power supply board 1000-16v. Now status LED blinks (orange) continuously. What does that mean?
After checking the filter cover and placing it properly, now the timer LED blinks continuously.After checking the filter cover and placing it properly, now the timer LED blinks continuously.
You can't post conmments that contain an email address.
Re: Mitsubishi Model # WD-62725
First, I replaced...
Hi, Status LED blinks (orange) continuously is an error code that shows that Filter Cover is not attached on tv front. Make sure it is fixed properly to avoid that error. Thanks.
If Timer/Power LED is blinking green slowly that shows On Timer is set. If Timer/Power LED is blinking normally that means Booting after AC applied, wait few minutes until it stop blinking then tv might show another LED On/ Blink Please recheck your power supply work.
That model will usually have 8 caps that require replacement on the Power board and also 4 capacitors on the DM board which will usually cause the Non stop blinking light symptom.
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I would suspect a faulty Zener or Diode, transistor, allowing dirty DC or AC ripple, to the Caps.. use a scope and have a look. One must always find the cause of why things fail simply fixing the symptoms simply means it will fault again.
I just repaired two Mit WD-62725 sets in the last two weeks.
The first one had bad caps on the power board and the FMT board. The scond one had bad caps on four out of the five boards.
Also, on the FMT board, there was a blown surface-mount fuse.
I advise checking all of the boards for bad caps. If you fine a bad 1000uf cap, replace all of the 1000uf's on the board.
Hop this helps,
Dan
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
ok here new tips on v26 chaisscust install new oem lamp with led lamp just blink only many time install new balister still shut down no audio no hv at all come with code 34 for test turn out to be that in power supply ther caps that wher blow up 3300 mf at 16v two them c9a38 ad c9a36 both same also note c9a62 1000mf at 16v thru c9a52 ad c9a82 ad c9a61 all 1000mf at 16v install 63v at 1000mf all same with both 3300mf at 25v fix the set now turn on with great pix cust old lamp too dark for pic install new lamp pic better ad reset lamp timer all good cust happy that cust got from mist the power supply board from looking from back of the set on left hand side all way in front u hav pull whole dmb bd to get to it want lets yu guys know[john leyva american video service center ] the right model number is this WD52525 HIT BAD KEY THIS RIGHT MODEL NO WD52525
replace C81A2 C81A3 C81B2 C81B3 on the dm module and C8F19 C8F21 C8F22 C8F27 on the fmt pcb all new caps should be 680uf at 16v instead of 1000uf at 16v
