Question about Frigidaire Washing Machines
I have a model #LTF294oeso washer & the control panel lights & dial operation works fine, but whatever cycle it is put on you hear the typical clicking sound to start the cycle but nothing happens or half the time the cycle starts but shuts off within 3 seconds. Thanks Dave
  • 4 more comments
  • dsmith33832 Oct 08, 2010
    The washer is a frigidare front load washing machine & all the functions of the control knob other than the drain function do not work.
  • dsmith33832 Oct 09, 2010
    I have a model #LTF294oeso front load washer & the control panel lights & dial operation works fine, but whatever cycle it is put on you hear the typical clicking sound to start the cycle but nothing happens or half the time the cycle starts but shuts off within 3 seconds. Thanks Dave
  • dsmith33832 Oct 10, 2010
    Thanks for the advice. It sounds promising but I am wondering if this noise happens periodically or happens all of the sudden because it never happened before but it all of the sudden doesn,t work at all. Every setting on the control dial doesnt even want to start except for the periodic time, the the cycle starts but shuts itself off within a few seconds. I called Frigidare
  • dsmith33832 Oct 14, 2010
    I have A frigidare front load washer model # LTF294oeso & was advised to replace the control panel which I just did but doesn't solve the problem. Every cycle from the control knob will start but within 3 to 4 seconds the machine will shut down. If I press start after stalling the display will flash 3 times Err & 3 beeps. In the trouble shooting Error codes it states 3 beeps senses problems of " Inlet valve,pressure switch or control board failure." Due to "drum overfilled" Solution supposedly is "Do not open door, select drain/spin to remove water, restart cycle." Does a faulty pressure switch or inlet valve cause the machine to shut down on every operation? Thanks, Dave
  • dsmith33832 Oct 16, 2010
    Would all the cycles breifly start if the door lock is faulty?
    Thanks for you recommendation no one from frigidare or on-line about pushing both start & cancel buttons together. The code that comes on the display is E5E followed by 5 beeps. In my manual I have an Error code chart that says 5 beeps means the motor is overheated & the solution is to wait 30 minutes for motor to cool down. Apparently that isn't the solution giving it's been cooling for over a week. I asked frigidare way back if there was a sensor for the motor that may be faulty but they said no. So I believed it wasn't the motor because each cycle briefly starts which I was thinking the motor was required to start the cycle, but as I said within 2-3 seconds it stalls & approximately every minute the cycle is on it starts again for the 2-3 second period. Thanks & I look forward to a response, unfortunately we are leaving Florida & driving to Pa. for a family emergency, but I will check my E-mail by Monday or tuesday. Thanks Again! Dave
    President:
  • 1,554 Answers
The machine doesn't start and flashes "Err" because a failure is detected. The failure code must be determined to know where and what the problem is, The code can be displayed by pressing any button to wake the machine then press the START and PAUSE/CANCEL button simultaneously. The failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. Post back the failure for further troubleshooting advise.
Please make you accept this post if you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how unhelpful or non-informative it is. Accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 14, 2010
  • Jahn27
    Jahn27 Oct 16, 2010
    Yesit will but will eventually stop. Read the error code and post back for accurate troubleshooting.
  • Jahn27
    Jahn27 Oct 16, 2010
    The code means communication communication problem between the control board and the motor speed control board. Disconnect power then check and make sure the wiring harness that connects the two are intact and the connectors are clean and fully inserted to both. Reseat the connections several times to ensure a good connection. The harness is connected to connectors J1 and J6 on the control board and connectors J1 and J3 on the motor speed control board.
    Once done with the harness inspection and connection and the problem is not addressed, disconnect the motor harness from the motor speed control board (J5) the reconnect power and start the machine. Compare how the machine operates when the motor is connected and when it is not then read the error code when it stops and post it back. The next thing you should do is disconnect connectors from terminals J1 and J3 on the control board and do the same.
    Please
  • Frigidaire Master
  • 8,220 Answers
This could be a bad door lock. My guess it it is not sending confirmation to the control.
Here is a link to a service manual for your machine as well as a ton of videos showing how to access components: Frigidaire service manuals
Posted on Oct 10, 2010
  • 2,272 Answers
Cycle Not Advancing or Timer Stalling Symptoms Update :---
One root cause of washer stalling in cycle (timer not advancing) on horizontal axis washers is electrical noise generated primarily by the timer contacts opening and closing which can interfere with proper operation of the speed control board. At times, depending on ambient environmental conditions, this electrical noise can cause the motor controller board to receive corrupt signals and remain on 'stand by condition' resulting in the cycle not advancing. By manually advancing the timer to the next step in the cycle or by turning the washer's power off and on, the electrical noise is discharged and the washer will perform until electrical noise may happen to interfere once again.
To resolve this issue, three jumpers have been added to the current motor controller board to reduce electrical noise levels around the microprocessor. Testing has proven this change to the board significantly reduces occurrence of control lock-up. The newest motor controller board assembly is Part Number 134149220.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 09, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. As the water is not draining and clicking is coming from the bottom so the issue seems to be with the drain pump solenoid.
Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. If you have already checked the drain hose/pump and still the issue is not resolved then it is the Timer that is bad and should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
  • Rylee Smith
    Rylee Smith Oct 08, 2010
    Hi
    Usually, these issues are related to kinked hoses & clogged drain pump & filter. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the washer. If you have already checked the drain hose/pump and still the issue is not resolved then it is the Timer that is bad and should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Then as I said it is a Timer issue.
Fuse blown on Maytag washer
Could have been a surge dont think its anything to worry about ....run and keep an eye on it ....
Apr 12, 2010 | Maytag PAV2300 Top Load Washer
Dial dosnt turn on its own to continue through
Hi, The timer has a motor that turns it. If you could get me a model #, I will look this up so I can see exactly what model you have. I have seen some dials hang up because something gets spilled on them and they get sticky betweeb the dial and the control panel.
With a model #. I can see if this is that style.
Thanks
Vic
Jul 18, 2009 | Dishwashers
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer stops half way through rinse
check the lid switch on the washer loosen the two screws on the control panel end caps pull the control panel slightly forward and tilt on its hinges then you will see a connector under the panel it has three wires one is gray one is green i think the other is tan unplug the connector and put a jumper wire from gray to tan to by pass the switch lower the control pane and start the washer to see if it continues if it does replace the lid switch
May 24, 2008 | Roper RAB2121KW Top Load Washer
Wash cycle moves to drain whatever the setting
Float switch in bottom of machine activated (leak) or pressure switch (or bottle for pressure switch) blocked or faulty.
Jul 10, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
