Question about Hand Tools
Ryobi battery will not hold a charge p100 18 volt, bd0737
3 Suggested Answers
Zerr0
SOURCE: ryobi 18 volt batteries wont hold a charge
Ryobi batteries are specific to each Ryobi model, so please write down which model number or the original battery part number you have. How old are the batteries?
I had the same problem with many bateries I had at home, like cell-phone batteries and also some power tool bateries. Did not have any Ryobi power tools tho, so don't hold me acountable if this doesn't apply to your hardware:)
Many batteries have the "memory effect" which means that if the battery was not completely empty when it was set to recharge it might now only recharge to the level it was emptied to, so for instance if you used the power tool for 10 mins and the battery emptied to, lets say, 90% capacity, it might occure that the next time you recharge the battery it will only charge to it's 90% maximum...doing that many times lowers the maximum recharge capacity. As I heard the new Li-Ion batteries do not have this problem.
I hope this makes some sence as my english is not that good and it was a bit hard explaining my thoughts:)
Posted on Nov 25, 2008
  • 78 Answers
SOURCE: ryobi 18 volt battery wont charge
no its best just to replace them
Posted on Jan 05, 2009
Ryobi manuals
YOU CAN GO TO GOOGLE AND DOWN LOAD THE MANUEL.JUST TYPE IN INSTRUCTION MANUEL ROYOBI CORDLESS DRILL 1048-67479CS LITHIUM BATATERY CB 120L YOU SHOULD BE ABLE TO DOWNLOAD THE MANUEL
Aug 12, 2014 | Ryobi Ridgid 12V Cordless Flashlight 12...
Why does ryobi 18V cordless not charge
Please check the LED status of your charger. If both of the charger'sLED flashing, but it can charge a good battery. Than the battery is defective, you may replace a new Ryobi P206 Battery http://www.batteryshops.co.uk/tags_products/ryobi-p206-12-18v-2-speed-drill-driver-battery_6854.html
May 11, 2014 | Ryobi 18v Cordless Drill - P206 18 Volt V
I have a ryobi 18V battery and the only charger I have is a ryobi 14.4V. Can I charge the 18V battery on that charger?
Hello, unless the charger specifies that it charges 18 volt, it will only charge a 14.4v properly. If the battery fits the charger physically, then the most you might get an 18v to charge at is 15 or 16 volts. Your battery life will be shorter and you might damage the charger. I hope this helps.
Jan 12, 2011 | Ryobi Garden
Earlier this year, I purchased a new Ryobi P103 LI-ION 18 V/24 Wh battery powered blower. In the past week, the battery isn't holding a charge for more than 5 or so minutes. Any suggestions?
Try to discharge the batts to the full end.Then try charge them agian for at least 12 hrs.
Or contact them at https://register.ryobitools.com/contact_us/new
Nov 03, 2010 | Ryobi Multi-Volt Battery Charger
How to fix an old RYOBI 18 volt battery won't
take a hammer, and apply force. These batteries dont last forever... but i am serious about the hammer... you may be able to free up whats inside (if you know how a batterey works.)... also apply heat.. try to hit it from all angles than slam it down on the back and leave it sit... than try. I hope this works for you my dewalt batteries over the years have don this, and it works.. but BTW. it wont hold a charge for very long anymore.. the battery is pretty much garbage.
Oct 13, 2009 | Drills
Charging
Negative partner, you can try all day everyday but 12 v is 12v and 18 v is much more. its just not gonna supply enough juice to charge the battery. the most youll ever charge it is 12 v... sorry.
May 02, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 18v One+ battery won't hold a charge. I have two of them and neither one will hold the charge. The charger is the Ryobi 18v charger plus.
Does it not hold a charge, or will the charge not indicate "fast charge"? I had to apply a initial jump charge on the battery to get it up to 20 volts, then I put it in the Ryobi Charger, and it started charging it.
Mar 29, 2009 | Ryobi 15" Electric Factory Reconditioned...
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
Jan 24, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 18 volt batteries wont hold a charge
Nov 25, 2008 | Hand Tools
Hand Tools Logo
199 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
