Question about Philips SA3125\02 MP3 Player
Right channel stops working
When I'm using it the right channel stops working. I have to twist and jiggle the wire around to get it to got on again. It's really annoying. Know a solution.
  • 8,596 Answers
No solution other than replacement. On the one hand, ALL mp3 players are sensitive like that. On the other hand, if you are experiencing the "one headphone only" issue, it is a hardware issue. no one repairs these. Replacement only.
-Tha Mp3 Doctor
Posted on May 30, 2008
2001 ford taurus stops while driving down road. There appears to be some type a jump in the wires on the right back quarter panel. Jiggle it and it cranks only to do it again.
you have a bad wire. you need to wiggle the wires and or check the connections and replace any bad connections. disconnect the battery when playing around with live wires to avoiding damaging important stuff. with the car off you should be allset. but if its battery wires or starter wires alternator or airbag. disconnecting the battery is a good idea.
Sep 17, 2017 | Ford Cars & Trucks
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
Left channel no sound on logitech headset
Usually something like this is simply the wire at the headseat becoming broken by twisting and stress. If you gently twist and push right where the wire enters the ear cup. It will work and then stop as the wire make a connection. Unless you can solder you will end up replacing the set. Make sure to try it out on a different pc or mp3 player etc just to make sure it is the headset.
Sep 10, 2012 | Logitech Audio Players & Recorders
My earphones suddenly stopped working all of a sudden. The sound in the left ear cut out and when I jiggled the wire and the connection a bit, the sound cut out completely. Now when I jiggle the...
Cutt the 3.5mm ********. You will need to cutt the cable about 10cm from the plug end to make certain you clear the damaged area. Buy a new Jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | Skull Candy Lowrider Headphones
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
The right ear has completely lost signal output. Anything I can do to save these awesome headphones?
check the wiring at the base of the right earphone .
try to put it on and giggle the wire around while listening to it .
the common problem with most head phones is the the wire is twisted too often and break at the base of the earphone .
If this is not the case , check the plug which could again be the same problem .
If the problem persist , the speaker could be faulty of one of the channels on the earphone output could be down .
Sep 27, 2009 | Philips HP-170 Headphones
I have a techniques SL1200MK2 Turntable that is giving me some problems. I have normal signal on my left side, and very low signal (if any) on my right. I've determined that there is a dead short...
Try swapping the turntable RCA cables around at the back of your aplifier or hi-fi to check if it is the same channel giving you problems. if the same side remains dead, it might be you RCA plug itself. Turn your "ballance" on your Amp, so that the channel that is still working, is muted. Jiggle the faulty plug around, and see if you get any noise from the dead channel. If that is the case, find an old set of RCA cables and cut one plug of to leave about 6 inches or so of wire. Do the same with the dead plug on the turntable, and strip both sets of wire back, and solder. Tape it up and give it a go
May 04, 2009 | Panasonic Technics SL-12002PK Turntable
Turning Signals keep blowing and signals cancel cruise control.
Sounds to me that the turn signal switch is bad and will have to be replaced. If you could wiggel it around and get them to work tells me that is wear the problem is.
Feb 11, 2009 | 2005 Chevrolet Cavalier
Left channel not working
The first thing I would check has already been done, the only other thing would be fuses. I am preety sure there is a protection fuse at ever channels output to protect against a dead short. I am sure you have already fixed this problem but I thought I would give it a try. Let me know what you found.
Jul 13, 2008 | Denon AVR-3802 Receiver
Philips SA3125\02 MP3 Player Logo
20 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
