Sharp el-470 travel clock calculator - Office Equipment & Supplies
How do I set the date on the Sharp EL-470 travel clock calculator?
Posted on Feb 18, 2011
The EL-470 uses a CR2032 coin battery
Posted on Feb 02, 2013
Please choose your download package
I've made a manual, but it's in german language. But in this u can c after all you're lookin' 4.
Al Swearengen
Posted on May 14, 2014
What battery is use in a El-470 Travel Clock Calculator
Posted on Jan 31, 2013
Setting up the Date & Clock after reset
Follow the instructions on the first page of this manual.
Apr 05, 2013 | Sharp EL-1197PIII Calculator
Ben travel 126 km in 21/2 hours. how many kilometers did ben travel iafter 3 hours
126km/21.5hr = 5.86km/hr This is how far he travels each hour.
Once you find this out you multiply by 3 hours because you want to know how many kilometers he traveled in 3 hours not each hour. 3 * 5.86= 35.16 km.
Ben traveled 35.16 Kilometers after 3 hours.
Jun 09, 2011 | Sharp EL-2630P Calculator
Setting correct date
You may download a copy of the manual here. The clock setting instructions are in the middle of the first page.
Sep 02, 2009 | Sharp EL-1197PIII Calculator
How do I print a date format with sharp el 1801PIII?
To print the current date press once the Clock/Calendar key and then press once the Non Add/ Subtotal key (# key)
To print out any other date (or codes and other numbers that are not part of a calculation) just type it and then press the Non Add/ Subtotal key (# key). The date/number will be printed preceded by the # sign.
You may also want to download the SHARP EPL-1801PIII Operation Manual
Jun 04, 2009 | Sharp EL-1801P Calculator
How do I set the date on Sharp EL-1801Piii
Adjusting the tiome is just like adjusting the date, owith the only difference that you just enter two values (hours and minutes):
1. Move the Grand Total/ Rate Setting mode selector to the "Rate Set" "position
2. Enter the time in the orde of hour, minutes (use a point to separate the two values) and then presse the [Clock/Calendar] button to complete the entry.
You may also want to download the SHARP EL-1801PIII OPERATION MANUAL
May 15, 2009 | Sharp EL-1801P Calculator
Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
Feb 17, 2009 | Sharp EL-1801P Calculator
Changing the date & clock
if this is on a ti calculator go to mode and at the bottome you can set the time and date
Dec 15, 2008 | Sharp EL-1750PIII Calculator
Sharp EL-1801V Calculator
Change the switch to Rate Set, then input the mm.dd.yyyy then the clock/time button then hrs (military time).minutes then clock/time button.
Apr 02, 2008 | Sharp EL-2630P Calculator
Time/Date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Feb 20, 2008 | Sharp EL-2630P Calculator
877 people viewed this question
jasbo
jasbo
