Question about JVC RX-D301S Receiver
I have the receiver setup for 5.1 channel sound. I never had a problem before I moved, but now, all I get is 2 channel sound. I have connected the the leads from the other speakers to the front speaker terminals to verify that there is nothing wrong with the speakers/wires.The receiver simply is only sending signal to the front speakers. This is constant for all input sources, either analog or digital.
  • izeman0302 Oct 08, 2010
    That's how I set the receiver up for 5.1 channel sound. All the speakers are lit on the display, but still only 2 channel sound. I have changed the levels as well to see if the others speakers have any output at all (i.e. turning down the levels on the front speakers while raising the others), but nothing.
  • JVC Master
  • 3,247 Answers
It is possible the system has gone into a 2ch speaker setting.
Check out pages 17 to 20 of your manual for speaker settings.
In case you do not have the manual you can download form this site. Click on download and Scroll down to enter the verification code displayed and start the download.
Hope this helps you to set the sytem up back it used to be. Please rate the solution so that fixya can help you better in future.
Posted on Oct 09, 2010
  • JVC Master
  • 11,800 Answers
For an unknown reason the speaker setup is set to 2.0 - just the front ones.
How to fix that using the buttons on the case, not the remote: press Setting and turn the MultiJog (selection button) until QUICK SPK SET appears on the screen; press Set; turn the MultiJog until 5.1 is selected; press Set; turn the MultiJog to select the room size; press Set; press Setting.
Posted on Oct 08, 2010
  • Azrael SRL Oct 09, 2010
    In that case the source coming in the receiver is a stereo one so this is what it outputs. You will have to enable Surround to get 5.1 from a 2.0 source.
How do I get sound to the second speaker zone?
The 5007 has 7 amp channels, so you can set up your main zone to be 5.1 channels and zone 2 to be the remaining 2 channels. Check the manual to see which speaker terminals on the back are connected to which speakers. You will need to go into the setup menu and set the amp for 5.1 + 2 channels. Then you will need to run speaker wires to Zone 2.
I recommend using banana plugs to connect the speaker wires to the 5007. They make a much neater install and eliminate shorts between connections. Sewell Direct makes nice plugs for a very reasonable price.
Mar 07, 2015 | Marantz SR5007 AV Receiver
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I bought a new TV for my #2, but is says I'm not getting a signal when I hook it up to the cable. I have it on channel 60
djpeter770
You can go to TV 1 to make sure TV 2 is suppose to be set to channel 60. Did you run the auto setup on your TV? If you have already run the auto setup on your TV, unplug the receiver from the electrical outlet for 10 seconds and then plug it back in. This will make the receiver reboot and re-acquire satellite signal. Then see if you get a picture on your TV 2. If not, the last thing you can try is changing the channel from 60 to 73 through the receiver.
With your DISH remote at TV 1, press the Menu button - Main Menu will display on the TV 1. Then press 6 (System Setup), 1 (Installation), and 5 (Modulator Setup). On the Modulator Setup screen, move over to TV 2 Out and select Cable, then press select on the remote. This will automatically change the channel from 60 to 73. Highlight Done on the right and press select. Cancel out of each screen till you get back to the TV screen. Go to TV 2 and put the TV on channel 73. You should get a picture. I hope this helps.
Ray Calo
DISH Network
Feb 16, 2011 | DISH Network ViP622 DVR DTV Receiver /...
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
Auto MCACC Screen Appearing
It would appear the unit thinks your McAAC microphone is inserted. Is it?
Automatically setting up for surround
sound (Auto MCACC)
The Auto MCACC Setup measures the acoustic characteristics of your listening area, taking into account
ambient noise, speaker size and distance, and tests for both channel delay and channel level. After you have set
up the microphone provided with your system, the receiver uses the information from a series of test tones
to optimize the speaker settings and equalization for your particular room.
Make sure you do this before moving on to Playing a source on page 11.
Important
• Make sure the microphone and speakers are not moved during the Auto MCACC Setup.
• Using the Auto MCACC Setup will overwrite any existing settings for the MCACC preset you select.
• Before using the Auto MCACC Setup, the headphones should be disconnected and the iPod
USB, XM or SIRIUS Radio function should not be selected as an input source.
1 Switch on the receiver and your TV.
2 Connect the microphone to the MCACC SETUP MIC
jack on the front panel.
Place the microphone so that it's about ear level at your normal listening position (use a tripod if possible). Make
sure there are no obstacles between the speakers and the microphone.
The Auto MCACC display appears once the microphone is connected.1
Note
1 • You can't use the System Setup menu in either the main or sub zone when the iPod USB, XM or SIRIUS Radio input source is selected. When you set ZONE 2 to ON (page 61), you can't use the System Setup menu.
• If you cancel the Auto MCACC Setup, or leave an error message
etc.
It's all in the manual.
Some background on the process...
http://www.pioneer.eu/eur/products/42/98/tech/AVAmplifierReceiver/AF_MCACC.html
Jan 30, 2011 | Pioneer VSX-1019AHK A/V receiver
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
JVC RX-D301S Receiver Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
