I have a Nordyne heater modle #E2EH-017HA. The heater will heat up but the fan will not turn on. You can turn on the fan manually. Any idea what is wrong?
    Problem Solver:
  • 10 Answers
Some times they use a bi metal switch its silver metal about the sizze of a dime.
or they might have a fan relay on a circuit board a small black rectangular shape device.
Ihave even seen the solder connections break away from the relay pins.
Posted on Oct 09, 2010
Nordyne E2EB-017HA air handler blower won't turn on unless I hit the housing. I can turn the fan easily by hand.
Very carefully give the blower wheel a spin and see if the thing takes off and spins. If so, you need to replace the capacitor on the indoor blower. It gives it the "boost" it needs to get going
Oct 26, 2013 | Heating & Cooling
Nordyne FEH-017HA-04 furnace fan is running full speed on ac but not on furnace
Multiple speed fans are always wired to run on "HI" for A/C and a lower speed for heat. If there are more than 3 wires on the fan motor, its probably a multiple speed.
Oct 24, 2013 | Electrical Supplies
Contacts are buzzing could it be the limiters gone
your contactor is going bad. its time to find one be for it stops on you
Apr 09, 2010 | Heating & Cooling
Blower motor doesnt always come on in heat mode
Yes if your creful. There is a sequencer inthe unit that operates the fan in the heat mode. It sometime sticks. This is due the moisture from the ac sweating. You van pick upa sequencer at HVAC parts house. Just wire back wire to wire and you willbe ok. Kill power to furnace first. Rus
Dec 03, 2009 | Refrigerators
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Feb 28, 2009 | Heating & Cooling
Blower will not come on
could be the fan relay is bad. or the run capacitor. if these check good. you may have a bad heat sequencer. hard to tell, if you thave a/c you can turn thermostat fan swith to on and if blower comes on then relay and capacitor should be ok. some units have two or three heat sequencers 1 controls fan and the others control heat strips hopefully this helps good luck
Jan 04, 2009 | Kitchen Appliances - Others
I NEED THE WIRING DIAGRAM FOR A NORDYNE MODEL #E2EB-017HA
contact nordyne local dealer and they should be able to get on for you. otherwise go to google and search for factor and e-mail them for 1.
Dec 11, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
206 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
