Question about Jl Audio 12W0V24 Car Subwoofer
My 12 inch jl seized up im wondering if its possible to fix or if i need a new sub
  • 400 Answers
If the voice coil is locked up, then its shot. Sorry.
Posted on Oct 08, 2010
  • Bobby Reed
    Bobby Reed Oct 09, 2010
    its all good ik the dude with the twin to it for a pretty good price thanks for the help
My legacy 12 inch subs are making a crackling sound what can do?
Hi rodneybarton
The problem of your unit may be its amplifier. You need to open the box and inside of it, there is a component that attached on the heatsink you need to replace that one. or better send your unit to qualified technician.
Dec 29, 2013 | Jl Audio Car Audio & Video
XA10002 dual channell amp pushing a single 12 inch JL Audio sub and continues to go into protection mode. All setting are turned to the lowest possible and remote wire, power wire, and ground wire are all...
Make sure you are wiring the sub to the correct ohm's. Some amps have a protective feature that will send them into protect mode if they do not since the right ohm load. If the sub is wired correctly double check your ground wire on the amplifier, and if that if also fine then your amp will need serviced.
May 31, 2011 | xXx XA10002 Car Amp
I have a 2011 gmc sierra and im putting a kicker comp vr 12 in there and i was wondering how much airspace i would need the box im looking @ is .98 i hope its enough airspace and its ported box
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch sub the box size will be 13 inches x 13 inches x 13 inches. Hope this helps
Dec 04, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
My cone on my JL W7 cone is cracked, How can I replace?
JL has good customer service, and usually you can get a drop-in replacement core/coil/former/spider. Call/e-mail the techsupport listed on their website, or contact your local dealer for replacement parts/service.
Jun 16, 2010 | Jl Audio 12W7 Car Subwoofer
I need to find a good sub box for my 10 inch JL w6
Hello ama1228a,
You did not say what type of vehicle the box is to be mounted into. Many times, where the box goes dictates the shape and size you have to work with.
That JL W6 will work OK in a sealed box with as little as .625 CuFt of volume and a ported box with .75 CuFt, so you have lots of choices.
Here's a link to the PartsExpress box page. These are Goldwood boxes, so don't let the prices scare you away. They really are built well, and one of them will make your JL sound good.
http://www.parts-express.com/wizards/searchResults.cfm?FTR=&search_type=main&WebPage_ID=3&searchFilter=goldwood+boxes
Hope this helps.
Apr 02, 2009 | Jl Audio 10W6v2 Car Subwoofer
Trying to find out wat the watts are on a jlw3 12 and a jlw0 12
The JL 12W0 needs 125 watts RMS. Sealed box it needs 1.5 cubic feet. Ported it needs 2.5 cubic feet.
The JL 12W3 needs 300 watts RMS. Sealed box it needs 1.25 cubic feet. Ported it needs 1.75 cubic feet. I wouldn't suggest running these subs together.
Jan 17, 2009 | Jl Audio 12W3 Car Subwoofer
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Jl audio amp 1000/1 fix
IVE HAD 2 JL 1000/1S DO THIS TO ME EACH TIME ITS TURNED OUT TO BE A SHORT IN THE RCA IMPUT BUT ALSO CHECK YOUR RCA CABLES AND THE SUB INPUT ON YOUR HEADUNIT
Dec 22, 2008 | Jl Audio 1000/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
JL AUDIO 12W7-3 SUB
the rottem electronic smell is the voice coil burned up as well as the bad sound, isn't the 1st time i have seen a JL sub blown. not worth fixing buy a new one the cost is not that much more repair on them is 250 - 450 depending on how bad it is and only JL can do the repairs as they dont authorize repair shops access to their voice coils. however i can sell you a new sub with full JL factory warranty drop shipped to your door for about 475$ or I could do you a way better sub ( the baddest competion sub made in the last 5 years) an olympus 2412 dual 2 ohm 5000 watt monster that has user replaceable voice coil options and is killing the competition circuit right now for about $275.00 shipped. it will stomp 2 13 w7's into the ground all day long. 2 subs vs just 1
Sep 17, 2008 | Jl Audio 12W7 Car Subwoofer
Jl Audio 12W0V24 Car Subwoofer Logo
326 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
