Question about Lexmark X4270 All-In-One InkJet Printer
Belt I'm unsble to slide the brown snd blsck belt to the left to remve the ink cartridges.
  • 426 Answers
Check to see whats jammed.... something is blocking it
Posted on May 30, 2008
Please let me know the direction of cartridges
You can follow the steps below to replace your ink cartridges.  Feel free to click on the link at the bottom to pull up a document that gives you information including pictures on how to replace the ink cartridges.
To take out the old ink cartridges:
When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.Pull the print cartridge toward you and out of its slot.
To install new ink cartridges:Remove the new print cartridge from its packaging.Remove the plastic tape by using the pink pull tab.Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.When installing the tri-color print cartridge, slide it into the left slot.When installing a black print cartridge, slide it into the right slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&cc=us&lc=en&dlc=en&product=1138373&tmp_track_link=ot_search
Apr 19, 2011 | HP Officejet 4355 All-In-One InkJet...
Epson D120 printer carriage goes to the left and stays there.
Yes I understand that, I think your proilem maybe that there is dirt/ ink on the slide bars. ( Sublimation ink ias notorious for imparting a residue)
So take a cloth and clean those metal rods that the cartridges slide along. They should reveal a lot of dirt on the rag. Then use some wd 40 or light sewing machine oil on another rag and wipe on wipe off. They only need a very slight amount.
I hope that is of help to you.
Please rate my help++++Thanks for using FIXYA
Jun 28, 2010 | Epson Stylus D120 Network Edition ultra...
I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
  • Press the "Power" button to turn on your Lexmark
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
  • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Nov 19, 2009 | Office Equipment & Supplies
Where do you insert the ink cartridges on lexmark x4650
These are the instructions for X2500 Printer
1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
2.Open the top portion of the printer to reveal the ink cartridges.
3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Oct 25, 2009 | Lexmark X2500 All-In-One Printer
Installing a new color cartridge
Hi mariek2006,
Cannon printers usally the ink is housed underneath the top portion of the printer. To open the top, reach down under the buttons or display area,, and left up, a blue plastic piece will slide out and lock the top into place. Once that up, look inside and the ink cartridge will eventually slide over to the left side of the printer. Look left towards the silver bar and you'll see two plastic holders for the ink. Take the ink cartridge out, by pushing down on the top edge of the cartridge, then out. To replace them, remember to remove the protective seal on the ink cartridge and put the ink cartridge in by holding the ink cartridge at an angle that has the copper control slip pointing upwards. Make sure you put it in below the top ridge of the plastic holders. Then once you slip the cartridge into the holder at the upwards angle, pull up again on the cartridge to snap it into place. That's it your ink cartridge are reset with new ink.
Good Luck
and don't forget to leave a rating based on my solution.
P.S.
Don't forget to push the blue bar that is holding the top up in, and the top will slowly lower itself into place. Mark
Aug 31, 2009 | Canon Office Equipment & Supplies
Where do i change the ink on my canon mp830 pixma?
Hello paulphipps1,
That printer the ink is housed underneath the top portion of the printer. To open the top, reach down under the buttons or display area,, and left up, a blue plastic piece will slide out and lock the top into place. Once that up, look inside and the ink cartridges will eventually slide over to the left side of the printer. Look left towards the silver bar and you'll see two plastic holders for the ink. Take the ink cartridge out, by pushing down on the top edge of the cartridge, then out. To replace them, remember to remove the protective seal on the ink cartridge and put the ink cartridge in by holding the ink cartridge at an angle that has the copper control slip pointing upwards. Make sure you put it in below the top ridge of the plastic holders. Then once you slip the cartridge into the holder at the upwards angle, pull up again on the cartridge to snap it into place. That's it your cartridges are reset with new ink.
Good Luck
Mark
Apr 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hp printer cartridges not moving
just finished taking mine apart 3hrs!!! ok cartridge not moving cause there's a little clip that's attached to a biger clip that's attached to the metal long rod in which the cartridge moves on top of got loose from the belt or just came of from the bigger clip.
now the little clip on mine came of and luckily i found it inside the printer.
steps:
1-took out about 10 screws to take cover off.(some sides snap off after removing screws)
2- remove 4-5 screws on top which holds a metal long slim frame on TOP of cartridge.
3- remove 2-3 screws from left side (facing back of printer) from the metal thin "ROD" on which the cartridges slide on top of.
4- lift up that rod and slide cartridge to left, mine didn't came out completely but enough to be able to work behind it.
5- if the little clip came off (and hopefully u found it)then reattach it to the belt.
6- take out the belt from right side, connect it again to the little clip, reconnect the little clip to the big clip, put back belt, big clip etc.
7- u have to play around a little to figure out how the clips go together and where exactly the belt goes.
GOOD LUCK cause i had 2 figure it out solo but finally finished w/ hands full of ink!!!
eddie kc
Nov 25, 2008 | Office Equipment & Supplies
Error 1200
turn on your all in one, open up front door and your cartridge door, slide brown and black belt (it has little grooves on it) to the left carefully till you can take out both ink cartridges, take them both out, snap them both in, then slide cartridge belt back to the right, close doors, turn on
May 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cartridge slides too far left
Keep your printer on, lift the lid should be right in the center.
Mar 03, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
