Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite model 596.76592600. 3 days ago ice maker did not work, installed a new water filter yesterday and ice maker started working several hours later. Last night the water dispenser stopped working and no water coming out today. The ice maker is working perfectly......but no water coming out of the dispenser inside the refrigerator. new water filter is 24 hours old...what could be causing this problem??
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
  • 100 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
fanny
  • 146 Answers
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Posted on Nov 03, 2007
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
Kenmore Elite model 59672286201. After installing new water filter, the ice is clumped together when it dumps, have to bust it with ice pick
you may have too much water coming in due to the extra flow from the new filter if you take off the front cover of the ice maker timer you should find an adjustment scew marked with a +/- reduce the cube size and the water should shut off sooner.
Mar 02, 2011 | Kenmore Refrigerators
Water dispenser does not work
the volve for the water is might be bad need to be clean or replace the volve to the ice unit is with the water but they seperate units...
Dec 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working but water is new filter elite 75542 40re1451
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
uittu
Jun 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The 596.xxx tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Jun 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
