Question about Sony Cyber-shot DSC-W200 Digital Camera
I got a system error message on my Sony CyberShotDSC-W380 camera. I am not able to shut it down.
    Brigadier General:
  • 3,006 Answers
It's most likely that your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Sony service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 08, 2010
Sony camera downloading
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Mar 30, 2014 | Sony Cybershot Dsc-w380 Silver
My camera canot take picture and focus adjustment,always showing error E:61:00 (sony cybershotdsc t-70 model )
Hello and Welcome to FixYa!
To solve Error E:61:00, Follow the given solution:-
Put the camera about a half inch from a hard surface.
Let the lens go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesn't fix it, try this:
Turn it on and let the lens go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lens a bit and blow in there a bit. (Be sure not to blow on the lens!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
Any more confusion, queries or for further assistance, I am here to help.
I hope this solution helps you
Thank you for using FixYa! Keep Visiting
Jun 05, 2011 | Sony Cyber-shot DSC-T70 Digital Camera
My Sony CybershotDSC-P200 camera works when it is plugged in, and the screen shows that it's charged. But as soon as I unplug it, it won't even turn on. Is there anything I can do to fix it? Would...
hi you might check battery first. sometime battery goes bad. if not then main pcb is the problem. your local repair shop could charge around $50 depend on what they really want to charge. Thanks...best regard!
May 21, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
I get system error....and it won't shut
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Apr 26, 2011 | Sony Cyber-Shot DSCHX5 Digital Camera
I want to change the language onto my camera, description below: Sony Cyber-Shot Model No DSC-W380. Please help me to change the language from Japanese to English, please.
Changing the language setting The screen language setting, press the MENU button, then select (Settings) > (Main Settings) > [Language Setting].
Mar 07, 2011 | Sony Cameras
My sony cybershotDSC-S700 camera shows horizontal purple lines in it's images shot.both the preview on the camera screen and the computer screens show the same lines.
Hi kris, it is most likely that your CCD is causing a problem, having worked with sony cameras for years, in my experience the only cure is CCD replacement. If the screen was a problem, it would not be ok on the computer. You will have to bring it to a sony authorized service dealer near to you. Hope this helps. Michael.
Mar 02, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Have sony vpc-s120 cam that states system error... lens goes back and forth and then buzzes. the cam shuts off after...
Hello
Unfortunately a "system error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Sep 21, 2010 | Sanyo VPC-Z380 Digital Camera
Screen message
Your battery is not making contact with all three contacts, thus making the camera believe you are not using an infolithium battery, creating the error message. Clean the contacts on the camera with isopropyl alcohol and the contacts on the A/C charger.
Apr 18, 2010 | Sony Handycam CCD-TRV608 Camcorder
POWER PROBLEM WITH SONY ERRICSON W380
it may be due to battery connector prob or due to the protection circuit connected to universal energy management system in the mobile phone being short circuited
Jul 06, 2008 | Sony Ericsson Bluetooth handset pink...
Sony Cyber-shot  DSC-W200 Digital Camera Logo
302 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
