Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I recently picked up a television from someone that was having trouble with it turning off/on by itself and found a capacitor solder joint that had burned out completely, expanding the pcb hole to nearly 1/6" in diameter. Is it crucial that I fill the hole with epoxy or would it be fine to just clean it up and run a bus wire from the trace?
  • RCA Master
  • 8,457 Answers
Do both for best performance,fill the hole with epoxy and clean it up and run a bus wire from the trace.
Posted on Oct 08, 2010
  • d_andis Oct 08, 2010
    Will plastic epoxy alone be fine or should I get an f4 rod to fill it? Also, the hole is kinda nestled between many components of course, what is the best/easiest way to clean the burn/carbon off the pcb?
  • Chi Chu Oct 09, 2010
    Used the plastic epoxy alone should be fine. Just used a small flat scew driver,scrapes the burn/carbon off of the PCB.Use a run a bus wire from one trace to another trace.
My TV is turning on an off itself with loud noise
The problem is most likely BAD OR DAMAGED SOLDER JOINTS between components and PCB...
it may be in power supply or motherboard..
please carefully check each and every solder joints, please use a magnifieng lens to observe the pcb for dry solders.
you must re-solder all the damaged joints..
May 03, 2016 | Samsung LN52A530 LCD TV
Found a Vizio VO42L By the dumpster and want to try and repair it. I plug it in and the orange logo lights up, press power and it turns on and the logo lights up white but picture flickers with horion
Sounds like it might be a solder joint. use the meter and check the ohms on each side of the solder joints on the board where the serial cables connect to the boards. it would be a good idea to check as many joints as you have time to. If it is a LED TV check Led control board for bad joints. if it uses Flourocarbon tubes check the transisters on each lighting control board. you may only have one board working causing partial back lighting.
Jul 29, 2014 | Vizio VO42L 42 in. LCD TV
My sylvania lc190sl1 changes channels by itself, goes thriugh the settings and will not turn off.
You likely have a power supply problem. You can take it in, or remove the back panel and inspect the capacitors on the power supply. Sometimes they will bulge if bad. If you find bulged capacitors, replace them with similar values using 105C temperature rated low ESL capacitors. You could also look for cold solder joints where the solder has loosened from the component leads.
Jun 09, 2014 | Televison & Video
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
My TV turns itself off and on by itself,
If you're having the TV set completely turn off, then on, which will be accompanied by audible relay clicks, then this is a problem relating to bad solder connections on the main or convergence boards which will require someone with a sharp eye and savvy with a soldering iron. Most of the time, bad solder joints will be around the convergence amplifiers or in the high voltage section.
Dec 19, 2012 | RCA P52930BL 52" Rear Projection...
Model # 52sx4d lg randomly shuts down, intervals between time has decreased recently, now wont power up at all
Well I just joined regarding a differant problem with my LG and seen this one.
I had basically the same problem with mine where it was randomly shutting off but would turn on by itself right after.
What the problem with mine was, was a solder joint on the power supply. Tech found 2 bad solder joints, repaired them and works great. This happened about 2 years ago. Hope that helps
Aug 16, 2010 | LG 52SX4D 52" HDTV
LG 50 PS 3000 tv will not turn on. Flashes a picture then turns itself off
Since your TV comes on and shuts off, the possiblity of the main power developing a fault on switch on to shut off as the error amp is asking it to do so.. Please check for any failure of capacitors in the HT section. use a multimeter and test voltage on switch on. make a note and test after it switches off. you will slowly arrive at the point of trouble. look for dry solder joints. use a good iron to carefully solder all joints suspected to look mushy. check the connectors of the HT drives to the panel. there could be fault in the connection resulting in slow build up and causing the error amp to react to shut off. Hope my advice helps. Good day
Jul 12, 2010 | LG Televison & Video
Convergence problem... Could it be bad solder joints???
if you have resolder it and still the trouble exist then that is the time to replace the ic.
Jul 28, 2009 | Sony KP-61HS30 TV
This TV constantly shuts itself off.
The issue has been resolved. I removed the back of the TV (pretty easy actually) by laying a blanket over the kitchen table and placing the TV face down. I started with the power supply as an obvious beginning. Both fuses on the board tested fine. And touched up every solder joint with a hot soldering iron in case the problem was a cold solder joint. After this painstaking venture, I performed another visual inspection and noticed a capacitor that had a thin black X on the top of the can. This is a common sign the capacitor has over heated. I located a replacement for $1.20, installed, and successfully powered up the TV. I have had no problems since.
Oh, yeah, I also paid $120 for a BN44-00150A replacement power supply, plus overnight shipping. It actually arrived three weeks later. That was two weeks and six days after I fixed the power supply myself.
Mar 05, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Samsung LNS4041D will not turn on
My Samsung LN-S4041d starting clicking and within two days would not turn on. I found an article online concerning the same problem with leaking capaictors. I pulled out the motherboard and my capacitors cm812,cm811,cm817, cm806 were leaking and/or bulged. I went to radio shack and purchased 4 1000uf 35v replacements. It took about 45 minutes to install, which I had never done before, and the TV works perfectly. It cost me $1.59 for each capacitor, $9 for a soldering iron, and $4 for rosin-core solder. Hope this helps your situation.
Jun 20, 2008 | LG 17LX1R 17 in. HD-Ready LCD Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
158 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
