Question about Samsung LE46M51B 46 in. LCD Television
Hello ive got same problem you get picture for 5 seconds and no picture just faint and there is sound. I sent it off to repair 2 months ago with same problem and the tech said no problem sent it back to me but charged me £200 is there any way of doing sumthing to refresh screen or anything please
  • Samsung Master
  • 3,187 Answers
If it is fine when it got to them it is the chip in the tcon board at the top they heat up pretty good. take it out of the tv. and put the board on some grease prof paper and put in the oven at around gas mark 6 get oven heated up to temp put the bard in the oven on a tray for 10 min with something fairly heavy and place it on the chip has to be flat on it. i used a weight 2.5 kg. turn off oven but don't remove for 5min then take out and leave to cool down. when it is cool down put back in the tv an replace the sponge square that sits on it you can get these off ebay or at maplins. should work fine after this is done.
Posted on Feb 09, 2014
5 Suggested Answers
  • 148 Answers
SOURCE: 3 horizontal lines during start ups(turning on)
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
Posted on Feb 02, 2010
eagle338
  • 4889 Answers
SOURCE: samsung hps5053 picture goes black but sounds
This is a 100% sustain board related problem. I have seen this a million times before. All you have to do is to replace the damaged capacitors on the sustain boards. It is caused by the inability of the damaged capacitors to carry on their rapid charge/discharge cycles. As for doing it yourself, it depends on your prior experience in working on high voltage electronics. The several thousand volts of residual voltage can cause permanent disability/death if not handled carefully.
Sai.
Posted on Nov 07, 2010
  • 324 Answers
SOURCE: we have a samsung 933hd. when we switch on, we get
This is a power supply problem. If the set is under warranty, exchange it.
If you warranty is expired, you can take it to a repair shop and get an estimate to see if it is worth fixing.
Posted on Feb 10, 2011
SuperTech-11
  • 1591 Answers
SOURCE: When I turn my tv
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. In your case, it could be either.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Jul 27, 2011
What is the repair for a Samsung LED television with sound but no picture?
Hello
disconnect and reconnect all the plugs and see if there is a change
Check the capacitors, if they are swollen on the upside, replace them and it will be fixed.
Good luck
Feb 27, 2016 | Samsung Televison & Video
"Fan lock"
Use the below link to locate ur nearest service centers ...
its an hard ware cognitive factor u alone cant rectify it ..
http://maps.jvc.com/cAscList/index.asp
Dec 23, 2007 | JVC HD-56FN97 56" Television
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
Bought element tv model flx-3711b in 2008, worked well until about a month ago start having problems, it start taking longer time to come on, sometimes picture comes on but no sound and sometime loud sound...
The problem you are having is a common and easily repaired one. The problem is caused by a failing power supply board. If you can do a little soldering then you should be able to do the repair. Check out this article on repairing the power supply in this model.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
If you don't want to do the repair yourself we do offer a repair service, you can use the link on that page to request service.
I hope this helps you, if so please rate our solution.
BuddyMc
Jan 11, 2011 | Element Electronics FLX3711B 37 in. LCD TV
I have a 2 year old Sony Bravia KDS 50A3000 rear projection TV. We replaced the bulb about 2 months ago and now all of a sudden the bulb will go off and we loose the picture for 35 seconds, nothing happens...
well if you replace the lamp 2 months ago this could be a ballast issue go to your back of the TV and if you ear a weird mechanical noises like a tick,tick when you are down there this is the ballast.
Regards
Dec 16, 2009 | Televison & Video
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Ps3 no picture no sound "no signal"
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
  • That's it, your video settings are reset and you should be able to choose your input and configure it from there.
Jun 02, 2008 | Sony Playstation 3 (PS3) Console
My Samsung LN-S4692D
before you give up..call samsung directly, they are very consumer oriented and if it is only a couple months out of warranty you might get them to repair it,, 1 800 samsung
Nov 20, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
SOUND NO PICTURE
Hello, You have a high voltage section problem I would not suggest fixing this set on your own. You will need to take this set to the shop. Because there are no user repairable parts inside of the set.
Sep 10, 2007 | Sony KV-36XBR400 36" TV
Samsung LE46M51B 46 in. LCD Television Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
