Question about Memorex MVDP1072 Portable DVD Player
Good afternoon:I have a portable DVD player with cover disk to open and close problem,A small plastic pin broken.And lost the small spring the open and close the cover.I will like to know where I could fine it. Portable DVD player model: MVDP1085-BLW
    President:
  • 2,777 Answers
It is going to be nearly impossible to find one and fix it yourself. You are going to want to try to go through Memorex on this unit... how old is the unit? It may be a free repair..
Tim
Posted on Oct 08, 2010
NAXA NPB 241 CD player has a spring just laying in there, trying to find out where it's supposed to go.
back right corner once you pop the top. there should be a little plastic hanger there, if there is not, it may have broken off. the spring attaches there and then there should be a small opening that it feeds down into and attaches to another hanger
Jul 24, 2014 | Naxa NPB-241 Portable CD Player, AM/FM...
My sylvania dvd player is only saying open on the screen and not reading any dvd's.
The problem is the switch button (signaling if the Cover is Opened or Closed)
locacted under the circle hole near the edge of the DVD disc is
MISALIGNED with small pin-plastic (located near the edge of Back DVD Cover)
whenever you close the DVD cover.
So what I did, I enlarged the cirle hole using a soldering iron carefully
and the switch is now visible. You can either make the switch
permanently engaged to On by pressing down switch and put a tiny glue
OR applied glue a tiny screw washer to make the pin-plastic
bigger in diameter. This will surely pin down the switch to On to
signal that the DVD cover is closed. Good Luck.
Roan
Computer Tech
Chapel Hill, NC
May 22, 2012 | Sylvania SDVD7014 Player
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
I have a Polaroid pdm-08228bd that whenever we put
when you open the cover for the DVD you will see the laser ..its a small lens like device mounted on a spring like assembly .. you can manually clean that laser with a soft paper towell soaked in eyeglass lens cleaning solution .. dont spray the solution on the laser directly .. make sure the spindle spins freely in the center where the disk mounts ... when you close the lid and turn power on you should be able to hear the disk spin .. if you can hear it spin and hear some clicking but still wont play then you likely have a worn out laser .. unfortunately the cost of installing a new laser is often greater than the cost of a new DVD player ...
here are a few models that might be worth looking at ..
http://www.consumersearch.com/portable-dvd-players?gclid=CITHuImPjaICFchD5godvmnzUw&ef_id=1953:3:s_241d3be5bdd1ae954a703c1c03b3e8bb_3674119072:TAxys0NIYWYAAGzz04MAAATA:20100607041651
Jun 07, 2010 | Polaroid PDM-0723 Portable DVD Player
Phillips PET 706 portable DVD player. Won't play DVD's.
1. The pin, right side in the back of the dvd-tray-lid, which triggers the switch on the motherboard of the dvd player is broken.
2. Not impossible, but unlikely: the proper switch on the motherboard is broken, corroded or just full of dust and does not close the circuit.
Solution to 1.: you need a new lid with intact pin, or glue an improvised pin on place of the broken one.
Solution to 2.: take the whole player apart (not difficult at all), while not disconnecting any cables, so you can now test the trigger switch (momentary switch) manually and see if something happens (on screen appears loading)
ATTENTION: BEFORE pressing the SWITCH: cover the laser lens with a piece of paper - do not look into it - it can damage your eyes!!!
If nothing happens by manually triggering, try to spray some electronic cleaner (fat and oil free) into that switch, while pressing it continously. If still nothing happens, disconnect battery, DC, de-solder that switch and look at mouser.com or any other electronic parts dealer to get a MOMENTARY switch with exact identical dimensions, etc.
Solder it in, everything should be perfect now.
Good Luck
Apr 05, 2010 | Philips PET741 Portable DVD Player
Numerous probs: 1)door won't open/close (if it does open);2)can hear (intermitently) mechanisms working when equipment is off; 3)will not detect DVD
I would suspect a weak power supply. If the power supply is not giving proper voltage, or even able to maintain proper amperage, then numerous problems will occur. One of my Ilos would take forever to come out of the "Hello" screen or open the door to load, or once you got a disk in it it would not recognize the disk. You could hear this grinding noise coming from it. Any of this sound familiar? On mine the two large capacitors on the power supply board were bad. If they are swollen then change them out. Radio Shack had them when I did mine, but most electronic supply store should carry them
Jan 10, 2010 | iLO DVDR04
I put a dvd in my portable dvd player and close the lid on the dvd player but it keeps sayin its open when its shut!! therefor it wont play any dvds!
LID SWITCH IS BROKEN, CHANGE IT OR THE COVERLID WHICH HAS A SMALL 3MM SIZE OF PLASTIC MATERIAL WHICH PRESS THE SWITCH WHILE CLOSING IS BROKEN TRY TO MODIFY IT...
Oct 13, 2009 | Goodmans GCE5000 Portable DVD Player with...
Conia M580 DVD player has died, cannot open disc tray to retrieve DVD disc from player. Cannot unlatch the disc tray manually, as there's no pin-hole near the disc tray, unlike most (more expensive) DVD...
Easy... follow these instructions
  • unplug from the mains
  • take the cover off (3 screws on back panel, 1 screw each side, sticker on top front)
  • You will see the DVD disk in the player drive
  • Remove the plastic ******** top of the drive - 2 x small phillips screws
  • Lift out the DVD disk.... done.
Oct 31, 2008 | Conia DVD8500 DVD Player
Cover fordisk holder is broken
You can trick the player into thinking the cover is closed and still play DVD's.
Open the lid and notice the small button on the top right side. Pressing the button will simulate the "lid down" so the disks will play.
You can even see the cool red laser when there is no disk.
Aug 10, 2008 | Durabrand DUR-1700 Portable DVD Player
Memorex MVDP1072 Portable DVD Player Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
