Question about Eizo CG301W Monitor
I recently purchased an EIZO CG301W monitor. When I connected this monitor to my computer (running Windows XP with a Radeon 4650 video card) the image at a resolution of 2650 X 1600) was certainly not sharp. Could you please send me a list of video cards that will produce a sharp image at a resolution of 2650X1600. Do you have any other suggestions for improving the resolution?
3 Suggested Answers
nileshsingh2
  • 246 Answers
SOURCE: I have an EIZO T962 CRT 21 inch monitor with bright screen
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Posted on Oct 16, 2009
  • 732 Answers
SOURCE: Eizo color edge 241W is the monitor. It starts up
pencilstudio, The electronics inside the monitor will need some work!! You will NOT fix with strokes to your keyboard!! And besides that, YOU'RE using your head!!! Most BLACK screen users fail to even try to verify the PC's VGA port with another KNOWN GOOD monitor!!! What you need to do is the flashlight test (trick) to evaluate the state of the units "switch-mode-power-supply". Reconnect 241W to a knowngood port that is sending WIN-desktop to monitor. Then and only then "turn-on" the 241W . Note how long you see the desktop for , before the LCD psnel goes to BLACK!! Then POINT bright flashlight 1 inch from screen and note if you can still see a very FAINT image of the desktop.. SEE= SMPS is in partial shutdown mode. NO SEE= SMPS in full shutdown. In any case, unit will need work done on it. If unit is still in warranty then have them fix it. If warranty not an option, then you or someone will need to do the work. Your monitor WORKS!!! Just not LONG enough!!! It can possibly be repaired with about $8.00 in parts, and you are capable of handling the labor part. Read some of my other responses to the more than 130 other BLACK SCREEN lcd owners. Follow the LEADS to other websites that will help you make the decision to do a DIY or to farm out the work as cheap as possible. DO THE RESEARCH FIRST. Then if you still are stuck for a solution, come back to fixya and make additional comment to this posting. 12fixlouie
Posted on Dec 23, 2009
Pixelated appearance
Hello Anon, it seems you may be looking at a driver conflict here. Setting up this project is easy; bring in a second monitor and prepare to swap between the two frequently.
1. On the Eizo's menu initiate the self calibration.
2. When the Eizo completes the self calibration and the Pixelation persists, uninstall all the Graphic Card drivers on your computer.
3. Install the manufacturer's specific graphics card drivers from the manufacturers website.
4. If the monitor continues to be pixelated then ensure that your GC is 4k ready. (That it can natively display 2560x1440 @ 16:9 aspect ratio).
I suspect your Graphics Card is not up to par, it likely has full 1080 but not enough to push 4k as your monitor natively runs. Purchase any GC with a 4k ready capacity and you will enjoy the full beauty of your purchase.
Source:
http://www.tomshardware.com/forum/304706-33-completely-uninstall-graphics-drivers-install-ones
http://en.wikipedia.org/wiki/Graphics_display_resolution
http://www.eizo.se/default.aspx?page=11&product=CG277-BK
Mar 06, 2015 | Eizo Nanao Eizo - CG277-BK 27"" Wide...
When i install my ATi radeon HD 4650 AGP card on motherboard the monitor does not boot. But when i connect the monitor cable to the onboard video card it boots well. Why
Depending on the OS you are running. Check to make sure that the device drivers were installed correctly while plugged in to the on board.
To do this on Windows:
open Device Manager by right clicking My Computer and clicking properties. From there you can click Device Manager (if on XP click on Hardware Tab).
Once there, you should see a selection that reads Display Adapterslogicaldemen.jpg
If it is installed correctly it should look like the one above (substituting in the ATI card)
If you see it and it has an ! or flag you need to update or install the drivers which you can get from http://support.amd.com/us/psearch/Pages/psearch.aspx?type=2.4.1&product=2.4.1.3.37&contentType=GPU+Download+Detail&ostype=&keywords=&items=20
Hope this helps
May 27, 2011 | Computers & Internet
I have a acer x163w 13" monitor and I am trying to play call of duty 2 but keep getting the input not supported. How could I fix this problem so that I may play this game?
Call of Duty 2 Minimum System Requirements
3D hardware accelerator card required - 100% DirectX 9.0c compatible 64MB hardware accelerator video card and the latest drivers*
English version of Microsoft Windows 2000/XP
Pentium IV 1.4GHz or AMD Athlon XP 1700+ processor or higher
256MB RAM (512MB RAM recommended)
100% DirectX 9.0c compatible 16-bit sound card and latest drivers
100% Windows 2000/XP compatible mouse, keyboard and latest drivers
4.0GB of uncompressed free hard disk space (plus 600MB for Windows 2000/XP swap file)
8x speed CD-ROM or 2x DVD-ROM drive
Multi-player Requirements
Internet (TCP/IP) and LAN (TCP/IP) play supported
Internet play requires broadband connection and latest drivers
LAN play requires network interface card and latest drivers
Supported Chipsets
ATI Radeon 8500
ATI Radeon 9000
ATI Radeon 9200
ATI Radeon 9500
ATI Radeon 9600
ATI Radeon 9700
ATI Radeon 9800
ATI Radeon X300
ATI Radeon X550
ATI Radeon X600
ATI Radeon X700
ATI Radeon X800
ATI Radeon X850
nVidia GeForce 2 Ultra
All nVidia GeForce 3/Ti Series
All nVidia GeForce 4/Ti Series
All nVidia GeForce FX Series
All nVidia GeForce 6 Series
**Recommend nVidia GeForce 7 Series or higher
Do your PC support the above hardware requirements?
The most common input no support would be your graphic card is not up to the mark to play the PC games.
Is your graphics card drivers up to date to the latest?
Have you updated your DirectX to the latest version?
Hope it helps.
Apr 17, 2011 | Acer X193W LCD Monitor
Monitor says "No signal" after restarting a few times. Using a DVI cable on a ATI Radeon 4650
swap your monitor with a working monitor. If same problem happens, then the problem is your CPU or your video card
Mar 20, 2009 | CTL Computers & Internet
My ATI RADEON HD 3870 over-clocked edition wont work. Plz help.
if your original graphic card was intecrated then u most first disable it in bios then u can use the new one
Dec 26, 2008 | VisionTek RADEON HD 3870 X2 Video Card -...
How to tell if computer hardware will be sufficient for Flight Simulator X
From the specs you have supplied, your friends computer should be able to run FS X just fine.
Matt
Apr 16, 2008 | Computers & Internet
Eizo CG301W  Monitor Logo
42 people viewed this question
Top Eizo Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
ShadeTek
ShadeTek
Raj Patel
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
