Question about Vacuums
How to open up a Bissell Powersteamer 1695
Not spraying so I think the pump is shot (it does hum). I've got the lower front part open but cannot get open the middle part to expose the main guts. I've taken out all visble screws but don't want to force anything. Is there a schematic anywhere?
  • PKslice Jun 03, 2008
    Wow great advice. Most of the screws take a bit of searching but I never would have though of peeking down the ends of the latch clips. Important note for pumps not working: I pulled the tiny motor away from the plastic pump and noticed it hummed but the shaft would not spin. It was seized with a some corrosion and **** so I took a pair of pliers and rotated the shaft on the motor a few times to work it loose, and now it works perfectly. I added a drop of fine oil to the bushings on the ends of the shaft as well.
    Thanks again.
  • 1,673 Answers
About the only thing you might try is putting a mix of vinegar and water and see if it will open things up. Your model, Bissell has obsoleted all parts, so the pump is not available anymore. But there are 2 screws, take off the 2 latches, at the end is a hole to take out a screw.
Posted on Jun 01, 2008
Need to buy a new motor for bissell power steamer
The motor for model 1695 is no longer available. You may want to try a local vacuum repair shop for old stock.
Jul 21, 2010 | Bissell 1695 PowerSteamer Vacuum
Cant get it to spry solution on to carpet hose pluged if so how d
It is because the pump belt is worn or stretched. Here is the replacement you need:
Bissell Proheat Pump Belt
May 19, 2010 | Bissell PowerSteamer Deep Cleaner Plum...
Bissel 1695 - pump not turning on. Vacuum turns on
bad switch or connecter at switch or the pump is plugged
Feb 22, 2009 | Bissell 1695 PowerSteamer Vacuum
I have a bissell powersteamer model 1697 that does spray water any more. Will a new water pump solve my problem?
check all lines from being gloggged /also check screen in the water tank on hose can you here the pump working
Oct 20, 2008 | Bissell Vacuums
I have a Bissell powersteamer proheat. The problem is that the unit will no longer spray water/cleaner out of the bottom of the unit.
Check to see if water will squirt out of the hose, if it does, then take the handle apart, the heater may be clogged. Once you get to the heater, take off the 2 water lines, dig out the clog, try to blow thru the heater to make sure it is open, then put back together. Otherwise it could be the belt, pump, seal not in place on the bottom of the tank or a clogged water line.
Mar 05, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
134 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
