Question about Sony VGN-NR220E/S Notebook
After installation of Windows 2010, the screen picture has lost definition...it appears like a scaled down, low pixel version.
    President:
  • 1,768 Answers
1. Your issue is with the resolution settings
2. You will have to sett the resolution in the control panel under "display for Windows 7 / for Windows xp go to this site for your instruction set.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
Posted on Oct 08, 2010
My picture is blurry,and words are blurry,what do i do
A blurry image on a high-definition LCD TV is typically the result of a mismatch between the TV's resolution capabilities and the resolution of the signal that is coming from connected devices, such as a DVD player or satellite TV receiver. Typically, blurry pictures result when a peripheral device connects to the TV through nonHD cables and jacks.
If your TV's connected devices do not have HD capability, they will transmit content to the TV in standard, analog signals. These types of signals are only capable of resolutions of up to 640 by 480 pixels. Pixels, for picture elements, are the tiny dots that make up the screen image. Most HD LCD TVs are capable of resolutions of as low as 1,366 by 768 pixels and as high as 1,920 by 1,080 pixels. When this big of a discrepancy occurs, the images display on the TV scaled, stretched and blurry.
Jan 24, 2015 | Televison & Video
How to change the screen size on a Westington TV
Hey,
In order for you to change the screen size on your Westington TV you have to press on Format on your remote (it is the button between the volume and the channel, right under the input button). As you press on it, it will change the display. From
  • Standard: Picture is displayed in its original size.
  • Fill: Picture is displayed to cover the entire screen.
  • Overscan: Picture is scaled down to fit the display area.
  • 1:1 Mode: Matches the incoming resolution exactly to the pixels without any scaling.
And now everything should be good!
Enjoy!
May 13, 2014 | Westinghouse 55" Class 54-5/8" Diag. - LCD...
Screen resolution is set incorrectly, don't get proper res (1200 x 800) when trying to change.
Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system. also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of colour range or troubleshoot also select advanced then general dpi Normal , Larger or Custom settings.
always click APPLY after making any changes
windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Colour and Appearance. Under Window Colour and Appearance, click the colour you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Colour and Appearance window, the theme might not be set to Windows Vista, the colour scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. Hope this helps.
Dec 07, 2012 | Computers & Internet
HP w1907 monitor has fuzzy text
Procedures of acquiring high definition pixel quality
1.power on the computer wait until the desktop of icons display after booting has been completed
2. using the arrow of the mouse or pointer to an area on the desktop without icons, right click to display a prompt list
3. locate the appearance and setting prompt on the list.
4. a click to provide the options to increase the picture quality termed pixels
5. LCD monitors could produce several thousand pixels, select a choice nearly approapiate for reasons explained
a. the highest selection of picture quality provided on the list for a monitor powered by a separate computer with extremely dense graphics like known for modern gaming could cause monitor to blank out as precaution.
b. when selecting a picture quality from the list provided on the appearance settings area after a right click on the desktop, be sure about the compartibility of the monitor and computer unit, explained
c. most modern retail provide system units with higest definition pixel capabilites for several funcitons as gaming graphic and design, connect such a unit to an old monitor would display low quality definition pictures. However, that could be fixed by adjusting the appearance setting only with caution not to select the most highest available from the list of pixels.
Dec 06, 2010 | HP w1907 LCD Monitor
I insert protector plus 2010 trial version antivirus . then it can currupt all program, no any program can ru properly. what can i do. thanks
Press F8 when you start your pc.
A screen will appear.
Select Safe Mode. Let the pc load until you see your desktop.
Then click My Computer, select C:
In C: , select Windows folder
In Windows folder, open system32 folder
Now, double click rstrui to do System Restore to the time before you install protector plus antivirus 2010 trial version
After system restore, you pc will restart and your files will be restored. Your PC will be ok again.
Nov 11, 2010 | Computers & Internet
What is the right ms office to download in my PC
for Windows 2000 OS:: Install MS Office 2000 for Windows Xp OS:: Install Office XP , MS Office 2003 For Windows Vista:: Install MS Office 2007 For Windows 7 :: Install MS Office 2010
Nov 02, 2010 | Microsoft Computers & Internet
Explain this phrase and give the solution. cyberlink youcam does not support a screen resolution smaller than 1024*768
  1. The resolution is about how many pixels are used to display images on your screen. How you change the resolution depends on what version of windows you have but they're all pretty similar. Hold the mouse pointer over your desktop (i.e. any programs that are open minimised)
  2. Press the Right mouse button and a menu will appear.
  3. In windows VISTA click "personalise" (in earlier versions click properties)
  4. Click DISPLAY SETTINGS (in windows vista, DISPLAY in earlier versions)
  5. You'll see a bar with HIGH at one end and LOW at the other end. Beside the bar it will show the resolution. If you slide the marker on the bar up or down the resolution will change. Set it at the resolution you need and click APPLY.
  6. You'll get an option to keep the new setting. Click YES if everything is displayed ok. If not click NO.
Sep 07, 2010 | HP Pavilion dv9000z Notebook
Black line half way down the center of the screen,about 1.5 inche
There's a 'data control' and/or 'address' problem that's developed. Pixels depend on voltage, control, and data coming too their designated address.
A digital circuit feature called a 'DATA_ADDRESS_ BUS" are responsible for 3 criteria: Delivering voltage, control, and data to each pixel in less than a second.
1) If voltage fails the pixels don't light up. They appear black in color (their 'off 'state)....numerous pixels that don't light up look like a black line. But their actually individual pixels with no voltage.
2) If control fails then all pixels are white in color (their 'on' state). Without control the pixels can't adjust properly to high or low 'state', meaning brightness and dimness. This looks like a white line vertically on the screen.
3) If data fails then the pixels can't adjust to the proper color at the proper time.
This appears as a line that changes color out of sync with the entire picture.
Have a technician look at the pixel address registry circuits. As well as control and linear circuits....the problem is somewhere in there!
Jun 13, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Can't click Accept in Software License Agreement dialog box in Ad
This is a simple work around, but it worked for me. Create a new user and make that account the Administrator. Log in with the new account an then run Adobe and click Accept. Some reason this worked for me. Good Luck.
May 17, 2009 | Adobe Acrobat 7.0 Professional
DISPLAY
they will have a low resolution . this is not computers problem try to zoom out hat pictures
Jan 22, 2008 | Computers & Internet
Sony VGN-NR220E/S Notebook Logo
26 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
