Question about Garden
I have a set of metal TV trays and the little plastic brackets that hold the top to the legs are broken. I believe the model # is 15-308. Can I buy a repair kit? I really like them.
  • Sonya Aug 20, 2013
    I wish I could find a solution, also! My set of T.V. Trays (model 15-468) are in good shape with the exception of the plastic clips. Why can't we find any??????
  • 760 Answers
Http://www.wclco.com/pdf/plastics/153-154.pdf Scrol down and look at these clips. You'll need some rivits to attach.
Posted on Oct 09, 2010
I have clippers model number HC95WV. I can not get blades back together
Ok place the small metal cutter on top of the large metal comb, place the white plastic piece into the top of the cutter with the protruding bit at the back, place the metal bracket with 4 holes on top first locating the front into the white plastic slot, then place the last metal bracket on top with the raised part to the front, then simply hold it all together and put the screws in form the back!
Hope I got the right blade style!!
Mar 18, 2014 | Conair Health & Beauty
Replacing a damaged top lid from a viking designer se
Yes it is loose in there on the plastic. The pressure from the other side holds it in place. You could install a small screw if you want to make sure it stays in place.
Dec 23, 2013 | Husqvarna Sewing Machines
Will not make ice
I have a Samsung RF265AABP model. I had the same problem on several occasions. One time the problem was a broken temperature sensor wire on the ice maker. The sensor assembly often gets snagged on the ice tray or scoop or something and falls down, making it more likely to snag, and prevents the ice maker from cycling when frozen. It is quite easy to remove the ice maker once you get the drawer removed from the slides. It is held in place by two plastic clips located near the back of the slides. Pop the clips out, and then lift the drawer out. Pull the front plastic cover off the ice maker, then remove the two screws holding it to the top of the freezer compartment. Slide the icemaker assembly forward about 1/2 inch and it will drop down. Unplug the wiring connector and the ice maker assembly will drop right out. The temperature sensor is located in a flexible rubber like unit that holds the sensor against the plastic water tray. This whole assembly often falls out, and may be found mixed in with the ice.
I fabricated an aluminum bracket from angle stock to hold the temperature sensor assembly in place, and used a small tie wrap to hold the wire to the bracket, up and out of the way after soldering the broken wire of course. The tie wrap is not shown in the photos below. I drilled and countersunk two holes for the 4-40 screws holding the aluminum bracket. The temperature sensor is not shown in the photo, but the wire comes out the right side and crosses over to the left in front of the aluminum bracket.
Aluminum bracket holding sensor in place.
Ice maker assembly showing screws holding it to freezer. It is upside down in this photo.
Sep 23, 2013 | Samsung RS2630SH Side by Side Refrigerator
Icemaker stopped
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. Check your digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
After fixing this problem several times, I finally made a metal bracket from aluminum angle, drilled and tapped 4-40 holes in it, and drilled the plastic icemaker to mount it more permanently. I added a wire tie to hold the temperature sensor wire up and away from possible snag sources. The sensor wire and wire tie are not shown in the photo below, but if you have the tools to solder the wires and fabricate a bracket it helps a lot. It is easy to get the ice maker out, once you discover how to remove the drawer from the slides (two plastic clips at the rear of the slides).
Pull the front cover off, take out the two screws, and unplug the wire connector and it drops right out.
Ice maker assembly upside down on bench.
Aluminum bracket and screws
Bracket installed. The sensor is not shown in this photo, but the wire comes out the right side and crosses in front of the metal bracket. The wire tie holds it to the bracket near the top center (hole not shown).
Sep 13, 2013 | Samsung Refrigerators
Samsung RSG257AABP stopped making ice. What to check before buying a new ice maker?
z
2q==
z
Sep 05, 2013 | Samsung Refrigerators
Model RS267TDWP/XA. Not making ice
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. On my model RF265AABP, I check the digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
z
2q==
z
Aug 11, 2013 | Samsung RF265AA Bottom Freezer French Door...
I can't get the ice maker to come on. What can I do?
Broken wires at the ice maker or the temperature sensor falling out can cause that problem. This solution applies to a different model, RF265AABP, but may be similar. Check your digital temperature readout at the top of the refrigerator with the doors open. If it reads 88 88 and has a flashing digit, check the ice maker temperature sensor for a cut or broken wire. The temperature sensor and rubbery gadget holding it in place often fall out of place when the drooping wires snag on the ice scoop or whatever. The sensor assembly is held in place by a wimpy plastic clip that breaks easily. Sometimes the wires get cut or broken when this happens.
z
2q==
z
May 03, 2013 | Samsung RB2155 Bottom Freezer Refrigerator
Dishwasher slides when both top and bottom trays are out at the same time
Please clarify if the dishwasher is tilting forward when both the trays are out.
If so there are ways to install the machine so that it will not tilt. If your dishwasher is installed under the kitchen bench and there is a gap on top, the machine will tilt from the weight of dishes once the trays are rolled out.
The legs are adjustable, therefore, free the hoses and power cord. Pull the machine out so that you can untwist the legs to a height suitable to minimise the gap. Just leave enough space to allow you to push the machine back in with ease. You can always pack in cardboard or phoam later when machine is in.
If after legs are heightened and you still have a big gap, the you need to get to pieces of timber cut on either top edge to fill the gap.
There are specialty brackets (e.g. L-shaped brackets) which you can buy and screw into the cabinet walls to hold machine in.
Some machines have holes on the side or top to allow you to screw in from the wall of machine into the cabinet. However, I do not believe Electrolux models have this.
Let me know if I have misunderstood your problem.
Ash
Sep 19, 2011 | Electrolux Dishwashers
Cannot clear error code 3523 for Kodak ESP 9200 Series all in one printer. Have followed all instructions per Kodak online
Had the same problem error 3523 that would not clear. Tried Kodak support with no results so took matters into my own hands.
Noticed the top tray seemed jammed into the printer. Tried pulling it out but it seemed locked. Flipped the printer over, removed 8 screws, 4 metal plates.
Removed bottom tray, set aside. Remove 3 screws for plastic bracket that holds top tray. Move bracket over, be careful not to damage wires. Remove top tray and reinstall so that it is in extended position. There is two notched in the side of the top tray. Extend so that catch is in back notch.
Reassemble everything in reverse order. Take care that the top tray does not slide into the printer when you turn the printer over. It did for me the first time that the tray jammed again.
Replug everything and startup the printer with top tray extended past bottom tray. The printer will tell you that top tray is jammed, push top tray flush with bottom tray.
Printer now works. Don't know why tray jams in the first place but this solution can keep you from scrapping printer or paying for service.
Very disappointed with Kodak printer. Obviously printers were not their core business and they paid a sub-contractor to build these products for them. My next printer will be an HP.
Jul 24, 2011 | Kodak ESP5250 All-In-One InkJet Printer
My dvd player (philips dvdr3400/37) says blocked.
My parents had the identical unit with the same problem. They fixed it by replacing it, and let the 3400 sit and collect dust.
I got sick of this so I set out to fix it today. EASY fix. Should take the novice about 45 minutes, and expert closer to 15 minutes.
This writeup is for educational purposes only, with varying skill levels in the world, I'm not going to be responsible for any damage you cause to your DVD player, yourself, your TV, your neighbor, or your cat.
You'll need:
T-10 Torx screwdriver
P-2 Phillips screwdriver
And a small slotted screwdriver, knife etc.. something to bend tabs back to unsnap plastic pieces.
Make sure the unit is unplugged first.
Remove 7 T-10 screws from cover (2 on each side, 3 on back)
Locate metal bracket over DVD unit.
Remove 2 T-10 screws holding bracket to bottom.
Remove 3 T-10 screws holding bracket to front.
Be careful you don't break the mount tabs, and don't touch any circuitry!
Remove 2 P-2 screws from black cover over DVD unit. Using your weapon of choice, CAREFULLY pry the tabs that are holding the black cover onto the DVD unit. 1 tab on each side, near the front of the machine.
DO NOT TOUCH THE LASER LENS!
With the removed cover in hand, locate 3 tabs that snap 2 white plastic circle halves together, Seperate the halves. Remove 2 washers. Notice one is a standard washer, and one is a strong magnet.
REVERSE their locations. Stack the magnets on the side that comes in contact with the DVD. Place the strong magnet on first, then place the normal washer on top.
I believe the cause of the "BLOCKED" message is this magnet being too strong/the opening mechanism being too weak. You need a magnetic field to center the white circle onto the base that the disc sits on, but too strong of a field causes the BLOCKED message to appear. Lessen the magnetic field and everyone is happy.
Reassembly is the reverse of removal.
Feb 10, 2010 | Philips DVDR3390/37 DVD Recorder
Garden Logo
1,975 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
