Question about Logitech Z-2300 Computer Speakers
Only one small speaker is working, it works from left or right outlet, bass isn't working and the other small speaker isn't working. What could be wrong
    President:
  • 1,768 Answers
Your main board located inside the sub woofer that controls and separates the sound
has lost it's ability to switch the sound. You will either have to buy a new speaker system or call the manufacturer to see where a service center for you speaker unit is near you for repair.
This also can be a bad volume control knob either way it will need to be serviced.
Posted on Oct 08, 2010
The bass in my Sony 3-way 6X9 speakers wont work
if these speakers are several years old, chances are that the left one is just blown. could be a loose wire, but if not, it would be cheaper to get new speakers than to get that one fixed
Apr 05, 2012 | Sony 3-WAY 6X9 SPEAKERS Car Speaker
Right Speaker not working... The bass and left speaker work fine but I'm getting no sound off the right
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems:
hope this helps you
Sep 23, 2011 | Altec Lansing VS2621 Speakers
I have Denon AVR-2310...but lost operating manual ! In audio set up, more specifically speaker configuration, a choice is given between " FTE", and "FTE +main". What is the...
The manual... http://www.retrevo.com/support/Denon-AVR-2310CI-Receivers-manual/id/23452bh638/t/2/
I'm pretty sure you mean "LFE + Main".
You need to identify the speakers to the receiver as Large or Small regarding their bass-handling capacity more than their actual size.
"LFE" removes the possibly overloading bass in a given speaker channel containing 'small' speakers and sends it to the subwoofer.
"LFE + Main" is sort of explained on page 29 "Bass Setting". The intent of LFE+Main is to task your subwoofer with the bass that ALSO exists on all other speaker channels regardless of their ability to handle it all by themselves. As you can imagine, this might make the subwoofer respond to sonic events that are actually supposed to be directional from, say, the rear channel(s). In that case the event might seem to come from wherever the sub is located instead of the intended direction; or at the very least it might seem to come from both places which is probably not what the sound engineers intended when they recorded the piece.
Having full-range speakers 360-degrees around PLUS a subwoofer, I don't subscribe to the 'bass-is-non-directional' school of thought. If you've ever felt the concussion from and subconsciously glanced toward one of the speakers after, say, a huge explosion, the system is working.
Sep 03, 2011 | Denon Audio Players & Recorders
Hi, I cant get my bas to work with 5.1 only with my front right and front left. what channel should i use? please help
Please rephrase. "5.1" and "only ... front right and front left" are mutually exclusive. Look at manuals.
In general, bass is 'managed' by directing it toward or away from any speaker the user declares to be LARGE or SMALL, usually based on arbitrary cone sizes instead of bass handling capability. There 'managed' bass is rerouted to the presumed capable LFE/Bass/Subwoofer channel to avoid potential damage to bass-shy speakers. Therefore, if one lacks a subwoofer one has to tell that to the receiver and designate the other speakers as LARGE or the bass will get tossed in the bit-bucket
Jun 18, 2011 | Samsung HW-C560S Theater System
The right speaker not working
Just opened mine just to realize that it only has on speaker on the side. Both sides dont have the bass speakers!
May 22, 2010 | Altec Lansing inMotion iM7 (021986950806)...
Bass not plaing only the small speakers, do i have it hooked up right?
I'm having the same problem, bass will cut out randomly everything is plugged in correctly if you bump the subwoofer it seems to come back on for a bit then back off, did you ever find a solution for this?
May 23, 2009 | Logitech Z-560 Computer Speakers
TEAC - CD-X9 - No sound in left speaker
the speaker wire itself could be grounding out. look for small knicks in the wire and make sure the plug is not faulty. RCA plugs can go bad which would account for intermitent troubles some times
Dec 28, 2007 | Teac CD-X9 Shelf System
Can i use small satelite speakers with my big front speakers?
Hi, I asume your setting up a home theater with five speakers a center left and right and rear surrounds don't know if you have a subwoofer. The large speakers in the front will work fine if you set the amp to large front speakers the bass will be sent to these. If you have a subwoofer set, the amp to small front speakers and the bass will be directed to it. Also try to get a center channel speaker that sounds somewhat like your large speakers.
Feb 14, 2007 | Yamaha AX-596 Amplifier
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Logitech Z-2300 Computer Speakers Logo
115 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
