Question about FIC REFURBISHED EVEREX IMPACT GC3500 PC/CRT PC Desktop
What is wrong with my computer`s sound card driver i can`t get any sound
Sound drivers
the sound card can be an onboard chip, built into the motherboard or a card installed into the mother board and thus more information is needed to assist you. You can get into device manager and delete the sound card driver/ items and then restart and windows could redetect it, or you can get the proper driver package from the motherboard, computer, or sound card manufacturer to reload it. I also can remote into the computer to determine what's wrong and attempt to fix it.
Can you give more info on the computer, motherboard, sound card or manufacturer of system ?
Feb 12, 2014 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Why no sound on my computer?
goto your computer icon,right click on it and go into device manger,and check to see if your sound driver are up and running,
try onboard sound first,then try sound card if you have one.
may need drivers.
Jan 27, 2014 | Dell Inspiron Computers & Internet
My sound aint working on my computer
may be u r usingthe wrong sound driver thats why u not geting any sound output... install updated sound driver from the official website of your sound card.. if problem persists then there might be some internal problem..
if your sound card is of REALTEK thn download sound driver from here : www.realtek.com
Mar 26, 2011 | Microsoft Windows 98 for PC
My computer keeps saying there is something wrong with my sound card or audio device does that mean that it is something internal. I've tried the troubleshooting and even tried the control pannel settings.
if you cant hear anything coming out of your computer speakers there is something wrong here what to do
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | HP (400745-001) Sound Card
It doesn't play any music, that the device is not install or used by any other proogram
first check bios wether the sound device is enabled then start your computer to OS right click my computer icon on the desk top click properties click hardware click device manager expand the sound vedio and game controllers you will see the drivers for the sound card installed if you cant find the reinstall the driver if the driver is marked yellow its a wrong driver or the driver is not installed corectly remove them and reinstall the correct drivers if its addon sound card go to the bios and desable the build in sound device and install the drivers in the sequence given above
Oct 07, 2010 | Computers & Internet
Dear Sir or Madam When I want to play a music on my computer , I get this error: "Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound...
Yes there is something wrong! The sound card driver is corrupted!
YOu need to check on device manager again. Look for your drivers there.
If you do not see the EXACT NAME of your sound card, then the driver that is installed is a DEFAULT driver made by the os.
Ex: This is a sound card driver name listed in Device manager:
IDT HIGH DEFINISION AUDIO
This is an example of a default sound card driver that will not work well on certain sounds or will not work at all:
LEGACY SOUND DEVICE
Even thought you many not see a yellow question mark (which you should be checking for too just in case)on any of the listings for your hardware, chances are you are still using a default sound card driver due to a corruption to its original sound card driver.
So recheck your device manager and find out the exact name of your original sound card. If there is no match to your exact name of your sound card, then you need to REINSTALL your sound card driver again and you will immediatly see your sound card working again :)
If this does not work, you may have to change your sound card.
Hope this helps :)
Mar 16, 2010 | Intel Motherboard
I installed a sound card into my computer and won't work what did i do wrong?
Go to device manager and make sure you have the right drivers.
Darren
Nov 20, 2009 | Asound Express PCI Sound Card
Have no sound
It is the sound card drivers problem. Either they are not installed or wrong drivers are installed. if the sound card drivers were not installed, you can find them on the motherboard CD which u got at the time of purchase of your Computer. Insert the CD into the drive and install the proper Sound Card Drivers for your relevant Operating System.
Nov 10, 2009 | Gateway E-2300 PC Desktop
There's no sound from my computer
It can be a defective speaker or there is no sound card, It can also be that there is no a driver for the sound card.
Jun 14, 2009 | Computers & Internet
Toshiba Equium Laptop m50-164
Hi, Alex,
I think you may have deleted your audio file driver on your laptop the only way to get your sound back is to re-install your audio driver for your laptop as the sound card on your laptop is ok you can find sound card drivers on the internet if you don`t have the drivers for your sound card
Jan 08, 2008 | Audio Players & Recorders
FIC REFURBISHED EVEREX IMPACT GC3500 PC/CRT  PC Desktop Logo
154 people viewed this question
Top FIC Computers & Internet Experts
David
David
Jax Planet
Jax Planet
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
