Question about E-Machines eMachines Desktop PC
It comes on but not windows just black screen with checking dm pool
  • 707 Answers
Try unhooking the CMOS battery (the little nickel sized battery on he motherboard), and leaving it out for about 5 minutes. This should clear the CMOS and might solve your problem.
Good luck
Posted on Oct 29, 2010
Wd62628 black lines across screen lamp light stays on
Hello, it sounds like the chip on the dm board is going bad, but a picture of the screen would tell me a lot more....tks
Jan 11, 2015 | Mitsubishi Televison & Video
Black smoke is coming out of the vent why
check gas pressure if too low it will soot up and overheat clean heat exchange after adjusting gas pressure
May 06, 2012 | Raypak 130,000 BTU Natural Gas Pool...
I have HP Webcam HD 3100 and with HP software I see myself, and on Yahoo Messengar if I run the wizard for sound or video I see myself on video. If I choose MY video or try to share my video with others I...
1: XP , must be connected to internet, are you? wifi or wired.
2: install the driver, or let PnP do that automatically or
go to DM (CP+DM) means control panel + device manager.
3: Right click the camera seen there. and pick update.
end.
Mar 20, 2017 | HP Webcam
Toshiba satelite on vista, comes up blue screen bad pool header then swithches off, then when i switch it back on, you here the dvd disc drive kick in but screen black, many thanks
First Update all the Drivers in the Computer, then remove the windows Updates which were done before the issue. Later use the Link to Download the Memtest86+ to check the RAM Module Stress.
http://www.softpedia.com/dyn-postdownload.php?p=13000&t=0&i=2
Now clean the registry using the any Registry Clean up application. This should resolve the issue.
Dec 01, 2010 | Toshiba Computers & Internet
There is a black screen with a white loading bar at the bottom when starting windows xp. this screen takes too long to load. please help me to remove this screen and boot to windows fast. thank you
i dont know how much ram do tuo have .If 256 or more may be hdd is affected by bad sector .download ontrack dm go for zerro fil if you have hbcd or any bootable cd where have the different dm go to bios .>restart >prees f2 or f4 or del go bios set boot piority cd rom >f 10>enter>when dos mode go to dm by select the actual drive ( drive letter >shift+:)enter>cd DM enter >ontrack enter >advance option> maintance >uttility>zerofil>select drive >yes enter.It will be possible if you know the D.O.S
Nov 11, 2010 | Computers & Internet
Screen goes black with green power light flashing. Then screen comes back on and 30 sec later repeats
after unplugging for 24 hours and hitting reset button. look at the replacement of the DM board capacitors.
Jan 26, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Screen is black on 52525. Setup menu still comes
Is this a Mitsubihi WDY52525 DLP set? First press the reset button and let the TV reset to see what happens. If still the same check all inputs to see if they all act the same (no pic/no sound) if they do then most likely the DM board is bad and will need to be replaced. I would suggest have a technician replace it for you.
Aug 15, 2009 | Televison & Video
DLP TV
It sounds like the capacitors inside the DM board is going bad or there is a problem with the FMT or formatter board. The DM repair will require replacement of four capacitors and if not done right away, the problem will get worse and burn out the IC's inside the DM and the DM will cost about 1000 bucks to replace! Good luck
Feb 11, 2008 | Televison & Video
Half of screen blacks out
sounds like power supply caps or caps in the dm board
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Mar 22, 2007 | Mitsubishi WD62628 62" Projection HDTV
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
