Question about Roper FEP310 Electric Kitchen Range
I Have a FEP310BW ccno 7.9 280 volt S/N FD1611647
2009 chevy cobalt has p0641 code with traction control turned off, engine in reduced power mode
Do you know anything about ECM five volt reference circuit's ?
DTC P0641: 5-Volt Reference 1 Circuit
The engine control module (ECM) has 3 internal 5-volt reference busses called 5-volt reference 1, 5-volt reference 2, and 5-volt reference 3. Each reference bus provides 5-volt reference circuits for more than one sensor. Therefore, a fault condition on one 5-volt reference circuit will affect the other 5-volt reference circuits connected to that reference bus. The ECM monitors the voltage on the 5-volt reference busses.
The 5-volt reference 1 bus provides 5 volts to the following sensors:
• The manifold absolute pressure (MAP) sensor
• The clutch apply sensor
• The fuel rail sensor
• The fuel tank pressure (FTP) sensor
• The intake air pressure and temperature sensor
You have a shorted sensor more then likely or wiring problem . Suggest you watch this video .
How to check the 5v reference circuit for short to ground Cadillac
Jun 18, 2018 | 2009 Chevrolet Cobalt
CAN i CHARGE A 36 VOLT BATTERY WITH A 24 VOLT CHARGER?
No of course not.
The charger has to be the same as the battery it is charging. On BIG batteries, it also has to have the power to handle the higher amps as well.
  • 36 Battery Charger Volts - 36 Battery Charger Volts - Deals! Ad · www.HomeGardenPro.com 36 Battery Charger Volts - Deals! Your Home, Your Style - Redefined.
    Handpicked Collections · Great Deals - Low Prices
  • 36 Volts Battery Charger ' Calibex.com Ad · www.Calibex.com/Electronics Cheap Prices and Huge Selection 36 Volts Battery Charger on Sale!
  • 36 volt battery charger in Batteries & Chargers ' eBay www.ebay.ca > Search > 36 volt battery charger Find 36 volt battery charger and 36 volt battery from a vast selection of Batteries & Chargers. Get great deals on eBay!
  • 36 Volt Battery Charger ' eBay ebay.com Find great deals on eBay for 36 Volt Battery Charger in Forklift Batteries and Chargers. Shop with confidence.
  • 36 Volt Battery Chargers ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Chargers in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Chargers - Electric Scooter Parts www.electricscooterparts.com/36vchargers.html 36 Volt Battery Chargers for Electric Scooter, Bicycle, Pocket Bikes, and Go-Karts. We have 36 Volt (36V) battery chargers in stock.
  • 36 Volt Battery Charger ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Charger in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Charger eBay
    Sep 20, 2016 | Health & Beauty
    How can I check charging system in scooty pep+
    The normal way is locate the battery, using a multi meter set to 20 volt DC check the volts across the terminals, if your battery is 12 volt the reading should be at least 12.5 and at most 13.5. If 6 volt the reading will be somewhere between 6.5 and 7.5 volts. Remove meter, start the engine, connect the meter back to the battery keep it set to DC and 20 volt. Note the meter reading at tick over and slowly increase the revs the voltage should rise to about 14.4 volts for a 12 volt system and maybe 8 volts for a 6 volt one. If volts to not rise then check regulator/rectifier, if OK check alternator.
    Dec 23, 2014 | 2008 TVS Scooty
    How many volts I have a charger that has different volts which one to set it on I have a whistler 1610 just trying to put the charger on the right voltage
    Most automotive electronics work on a 12 Volt DC system. You must be using adapter capable of providing about 12 to 14 volts because car batteries provide 12 volts; but car alternators put out 13.8 volts. Do not attempt to connect to an adapter that put out AC voltage!
    May 21, 2014 | De-1610 Radar Detector With Car Charger
    Transformer AC 9 Volt, battery 4x 1.5 Volt DC. On
    first is no i would not recommend feeding the 9 volt dc through the actual 9 volt ac it may damage the bridge rectifier that converts the ac to dc
    Aug 08, 2013 | Sangean ATS 909 AM/FM/SW Radio
    I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
    If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
    Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
    Sep 07, 2011 | Whirlpool Dryers
    Need to charge battery not sure if my charger should be on 6 volt or 12 volt
    VERY unusual for a 6 volt system, they just do not work. Count the fill holes, usually there will be 6. Think 2 volts each. To be sure, hook up a volt meter and see, but it just HAS to be 12 volts. Been that way forever.
    Feb 18, 2011 | 1986 Honda VT 1100 C
    How do I know if my Hotpoint oven 920 years old0 is on a 220 0r 120 line? The serial plate says 120/220.
    An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
    The 120 is used for the lights. The 240 is used for the heating elements.
    A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
    There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
    Charlie
    Jan 11, 2011 | Hotpoint Ovens
    Is a Hampton Bay HBD240A window A/C 120v or 240v?
    I have never seen a 240-volt window A/C unit for the U.S. market. So, my guess is it's 120 volt.
    The best way to verify this is to read the name-plate on the unit.
    Another way is to look at the plug on the unit's cord. There are at least three types of plugs :: 120 volt, 15 amp; 120 volt 20 amp; and 220 volt. 120 volt 15-amp will fit a standard household wall outlet. The 120 volt 20 amp plug is similar to a 120 volt 15 amp, but will not plug inot a standard household outlet. The 220 volt plug is altoghether different.
    Charlie
    Jan 08, 2011 | Heating & Cooling
    24 volt charging problems .2 12 volt batteries 1 battery 16volts and the other about 9-10 volts
    A 12 volt battery is actually 13.2 volts fully charged. If you are reading 16 volts, you are probably getting extranious voltage from the system somewhere, especially if the vehicle is running when you check the voltage. The alternator will put out about 15-18 volts to charge the battery normally, and yours may put out 28-32 volts to charge them in series, but the batteries, when disconnected, should never read more than about 13.2 volts each. Typically, it will read about 12 1/2 volts when disconnected. COMPLETELY DISCONNECT BOTH OF THE BATTERIES. If you still read 16 volts when it is disconnected, you must have a bad meter because the battery can't produce that much voltage, no matter what. (Six 2.2 volt cells connected in series inside the case.) Put the meter on a known good battery on another car that is not running and see if you get the same reading. It sounds like the other battery is almost dead, regardless, and it sounds like your series/parallel switch may be malfunctioning. (That is the switch that puts the battery in series to run the 24 volt starter, then puts the batteries in parallel to run the remainder of the vehicle on 12 volts. This is all assuming that you have a diesel vehicle with a 24 volt starter and that is why you have two batteries.
    Aug 19, 2008 | Toyota Land Cruiser Cars & Trucks
    Roper FEP310 Electric Kitchen Range Logo
    124 people viewed this question
    Top Roper Kitchen Ranges Experts
    Justin Duby
    Justin Duby
    Craig Butler
    Craig Butler
    Jim Thurston
    Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
