Question about GE Microwave Ovens
Is there a paint i can use to cover a scratch inside my microwave oven
    Champion:
  • 248 Answers
High heat paint as used for grills,or high temp.applicatoins
Posted on Oct 09, 2010
Arched from recessed area next to light
Your description is a little vague. I am assuming that you are saying that the inside of the unit has black scorching marks near the area that the interior light bulb is housed. If that is the case then the coating on the inside of the microware is compromised. This is usually caused from food particles getting stuck the inside or it has become scratched. When this happens, the microwave will continue to spark in that area, This will result in further black marks and it will cause the entire unit to fail at its most expensive part, sooner. You can take care of this issue by cleaning the interior very well and then paint the inside again with microwave oven paint. It has to be special paint.
Mar 26, 2014 | Microwave Ovens
When i use the microwave it makes a very loud coughing and spluttering noise and there is a flashing of lights inside. It also smells of smoke. Any help greatly appreciated. I live Bristol, England if they...
proceed according. God bless youIf you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
Apr 04, 2013 | Samsung CE1031B Microwave Oven
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
see the guide for test the magenetron and another component.
Oct 03, 2012 | Kenmore Microwave Ovens
Sparks when starting then goes to pause mode
see this next steps. God bless you
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
Jul 26, 2012 | Microwave Ovens
My oven is starting to arc. Does it need to be cleaned? This happened to my last oven and it was not repairable
if you are seeing the arching inside the unit throught he door you have exposed metal somewhere they use a protective coating on the inside and when paint wears off or has been scratch off and any exposed metal will cause it to arch... they sale touch up paint that can correct problem at most appliance stores and some home depots/ or lowes hardware stores.... good luck to you
Jan 09, 2011 | GE Advantium 120 Convection/Microwave Oven
The plastic cover on the window of the door is peeling. iIs there any danger in this? Other than that the microwave is working perfectly. Does this cover or the microwave have to be replaced?
The plastic cover on the door stops food particles and steam entering the inside part that is not easily cleaned.
That's all.
It is like thick selotape.
Jan 03, 2011 | Emerson 025806092806 Microwave Oven
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
I have a GE spacemaker. It releases electric volts when is turned on . Needs to be changed or can be repaired?
Do you mean "sparks" inside the oven cavity when it is operating ?
If so, check for grease spots on the wave guide cover or scratches on the oven liner. Scratches can be touched up with touch up paint and wave guide cover`s can be replaced.
Hope that help`s, good luck.
macmarkus :)
Feb 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
207 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
