Question about Sony PS-LX250H Turntable
Turns off I have a sony ps-lx5 but I'm sure most turntables are simular. I turn it on and the arm sits on the record for a few seconds then returns to the cradle. I've tried 45's and 33's and it does the dame thing. It's been very reliable until now. Some help please.
  • 4 more comments
  • musicperson Jul 21, 2008
    My PS-LX250H has been working until today. It starts, the arm moves over the record, drops on the record for less than a second, goes back to it's resting position and turns off. This is the pattern for any and all records. I have no idea how this problem got started. No clue how to repair it.
  • Anonymous Oct 02, 2008
    The same thing happened to me. I have no idea how to fix it.
    I'm having the same problem. I have no idea how it started.
  • Anonymous Dec 18, 2008
    i am soo disappointed. this is obviously a defect for many users. This is so not like sony.
  • lakeheadstu Jan 17, 2009
    I hate this damn turntable. Whenever the platter starts spinning it initiates the stop sequence. This happens when I press START and when I raise the tone arm and move it over the record.
    As well, many records will skip on my turntable but will not skip on others. I wish there were adjustments on the turntable for antiskate and tracking force, but I guess sony didn't think we needed them.
  • Maggie1234 Mar 19, 2009
    I have a sony Ps-lx250H turntable and only had it for a couple of months. The arms touches the record but then lifts off again and goes back to the cradle. The records are cleaned and just cleaned the stylus.
I had the exact same problem for a while, but was able to fix it. I somehow disabled and turned off the stopping sequence completely by lifting the platter, and rotating the plastic cog counter clockwise to it's limit. Somehow this odd solution worked great. Though I sacrificed the stop sequence, it saved me money buying another one and also the extreme annoyance of the dysfunctional arm.
Posted on Aug 15, 2009
If you look at the main gear there are 2 metal pieces (one on top of the other )if you add a little more grease between the two (give it a little more friction) that has fixed the problem for me
only needs very little . i took some from underneath the bottom metal piece and put it between
Posted on Jan 10, 2009
  • 515 Answers
Sounds like the gear for the tonearm might be damaged. No easy fix on this, will need to take to a service center for repair.
- Davis
DIGITAL ANALOG THERAPY
www.repairnyc.com
Posted on Jul 12, 2008
I'm having the exact same problem! It is so annoying.
Posted on Oct 02, 2008
I've recently picked up a Pioneer Plx-88z turntable second hand. I know that the player is working ok as putting the arm on the record plays music. The problem is that after a few seconds, no matter what,...
Hi, if it's a second hand device. there must be something wrong with the arm at it's moving axe. if something (dust or broken support) is blocking it, it will return automatically to its rest position to avoid any damage to the fragile and sensible "head"
Jun 02, 2014 | Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
I need to balance my tonearm for sony ps242. I have no instruction manual.
Generally on the end of most arms is a weight. These often have numbers. These weights turn or adjust, to one of the numbers. Ideally you should set it to the specifications of the cartridge fitted. If you are not certain set it around 2 or 3, then try it out with a record. The stylus should sit nicely on the record with no rumbling noise. This would indicate it being set to high. If too low the stylus will slide on the record and jump out of the groove.
Sep 02, 2013 | Sony PS-LX250H Turntable
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
TONEARM DOES NOT RETURN AT FINISH OF RECORD MODEL PS-X7
http://www.youtube.com/watch?v=PS6g9rQRF9M The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own.
Jan 31, 2011 | Sony Audio Players & Recorders
Sony pslx250h
Did the problem exist on its own uncorrelated to anything you may have done?
Does it return and cycle itself off or is it just rebounding aimlessly?
Unfortunately, there are no user adjustments for tracking, antiskate, end-of-play-return, etc. The only recommendation from the manual is to make sure the turntable is level and the records are clean and unscratched.
Mar 19, 2009 | Sony PS-LX250H Turntable
Crosley CR79 4 in 1 Entertainment Center
Wild guess but try this with the power off. Rotate the platter clockwise about 5-10 turns. You may feel internal mechanical engagement as you do it. The cueing mechanism may cycle it through its motion and return it to the rest.
Jul 08, 2008 | Crosley 0187SST Turntable
Won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Jun 04, 2008 | Sony PS-LX250 Turntable
Sony PS-LX250H turntable won't turn
check the switch that make the lp running located it on the arm (arm uses to put it on the LP) check the motor Make sure no debris whatsoever that can disrupt the LP to turn
Aug 06, 2007 | Sony PS-LX250H Turntable
Sony PS-LX250H Turntable Logo
463 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
