Question about Dell Dimension 3100 PC Desktop
I am getting blue screen with error of partmgr.sys. i did clean boot, it was fine for a day but it happen again.
    President:
  • 2,291 Answers
Check the size of Random Access Memory (RAM) in your computer. Its small size could be the reason for this problem as many of today's software need large amount of memory to operate in smooth manner. Additional RAM will also increase the efficiency of your computing particularly for gaming.
• Excessive use of computer or a malfunctioning cooling system can make computer/laptop overheated. Whenever system is heated, its efficiency will go down. BSOD is one possible consequence of over heated system. Keep fan of your computer in fully functional mode.
• Registry is the most vital part of Win 7. Corrupt registry is the biggest reason for BSOD in Win 7. One way is to clean registry manually but manual tricks could wreck your system completely if you are not a top notch computer expert. More appropriate way is to buy a good registry cleaner reginout and PC optimizer
Posted on Oct 12, 2010
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
When i plug the hard drive my computer wont detect. only the bios can detect.and i cant reformat it it says.a problem has been detected. i boot it from cd and after the windows setup it displays" a...
This usually happens when u fit any hardware to the system....The information which u gave seems its "Blue Screen of Death" or "BSOD" ........ if u have seen this screen only after u plugged in yr HDD, try with other HDD. Perhaps there might be an error with the HDD which u have plugged in.
Jun 13, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
A problem has been detected. i boot it from cd and after the windows setup it displays" a problem has been detected and windows has been shutdown to prevent damage to your computer the problem seems to be...
If you're running Windows XP (Any version) or Vista open the link provided below for instructions on how to repair you're master boot sector other wise known as fixmbr; http://helpdeskgeek.com/how-to/fix-mbr-xp-vista/
Read everything.
Mike
Jun 03, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
Laptop won't boot - gray screen
Dear user,
Your it seems that the LCD panel of your laptop is not working. and the sign of clouds is the sign of broken or screen pressed LCD. thats why the LCD did not work properly.
Please consult with qualified technician and tell him to check its LCD.
I am hopeful that you will understand my solution well.
Thanks
Sep 28, 2009 | Computers & Internet
Xp
Hi There,
I just experienced the same problem you did concerning the partmgr.sys blue screen error. I am installing Windows XP Pro SP2 on a pretty old Dell Latitude LS (upgrading it from Win 2000). The XP installation disk gives me the option to format in NTFS, FAT, and both formats in a "quick" mode. I usually do not recommend using the quick mode, however, after trying both NTFS and FAT and receiving the blue screen, I decided to try NTFS (quick). That has allowed me to actually get further into the installation, so you may want to try that.
May 27, 2009 | Microsoft Windows XP Professional
Error
That error is your partition manager, Go to this site and download Partition Magic
http://www.powerquest.com/partitionmagic/
This normally happens when you have got more that 1 partition on your hdd....
Try Partition Magic, and see if resolves your problem
Good luck
Chow
Blue screen ACPI.sys on install (brand new system, first install)
my client office one system working windows , when booting time displaying blue screen error" acpi.sys " . and then continusly system restart., but, i was maked the first and second repair, still now i didn't got solution for this problem. please help me. and also i want need ur help for blue screeen error.
May 15, 2009 | ASUS Computers & Internet
Partmgr sys
did the computer originally come with windows xp or an older operating system?looks like you may have some hardware issues.download ultimate boot cd from this link.Follow the directs to burn the image to disc.Boot from the CD and run memtest to check your memory,then run any of the hard drive diagnostic tools from the hard drive manufacturer.Let me know what happens after that.If none of the hardware fails I will recommend using one of the hard drive formatting tools to do a low level format on your hard drive and try installing the operating system again.note,if you have files that you need on the hard rive you'll lose them if you reinstall the operating system without backing them up.
Aug 21, 2008 | Computers & Internet
Partmgr.sys
Can you boot into safe mode? You can access safe mode by pressing F8 before the windows logo appears on start up.If you can access safe mode without any errors,then the problem is likely to be caused by a driver.Let me know what happens.
Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Jan 28, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3100 PC Desktop Logo
89 people viewed this question
Alun Cox
