Question about Pitco Frialator SG14 Deep Fryer
Operait the filtering sistem - Pitco Frialator SG14 Deep Fryer
  • Pitco Frialator Expert
  • 684 Answers
Hi there.
You can download Oil Filtration procedure for Pitco at http://www.pitco.com
Regards.
Posted on Jul 11, 2011
Why wil my McCulloch 3200 chainsaw not start after changing the fuel lines?
There is air in th sistem. Try to use a easy starter spray can into air suply. Remuve th air filter first. That will start th engine and keeped runing untill all the air in th fuel lines is out of th sistem. Or it should have a litle finger pump u can find in th chainsw
Nov 23, 2011 | Garden
Operaiting instructions please.
Hi there.
You can download Owner's Manual at http://www.tefal.co.uk
Regards.
Aug 19, 2011 | Tefal 61621 Steam Cuisine 2-Cup Rice...
How to reinstall the operaiting system which had been corrupted
you need reinstall it from Cd, dvd or recovery partin, if it present. If you want to restore your old system, it is unother mean, you must download any livecd, write it to disk, boot from it, then / restor my pc an earlyer time./
Jun 01, 2011 | Computers & Internet
I have the check engine light on, the engine will start and run at idle when the rpm's are incresed it sound like it has a bit of a miss at about 4000rpm and when throttle is let off the engine stalls...
Probably the fuel filter or pipe is partly blocked. When it runs at idle it has inough fuel. When you push the pedal it cant suply inough fuel and the engine sucks the fuel sistem dry, thats why it is so hard to restart the engine. Ewery time, when you turn on the egnition, the fuel pump in the tank is working only for three or more seconds. Because of blocked fuel pipe, or filter, it takes more time to pump up the fuel in the sistem. Chek the fuel filter and blow the fuel pipe.
Jan 01, 2011 | 1986 Saab 9000
Po171 code keeps coming up, I changed the fuel filter. Pressure at fuel filter is 45, pressure at fuel rail is 45. Pressure is 50 with pressure relief valve disabled. Diaphram is good at pressure...
did you check the o2 sensor bank 1 ? cause de p0171 code say sistem too lean bank 1 do you need replace this sensor and get a better fuel saving . or maybe is disconected or the o2 sensor wires could by cut o burn, i think about you problem is not the fuel sistem . clean again carefully the maf sensor without broke the tiny couple wires thks
Aug 07, 2010 | Ford F-250 Cars & Trucks
Motor oil in air filter
get rid of it quick. bad valves piston rings major engine over haul. i bought one with no oil in the filter 2 months later oil in the filter and engine blew. guy ripped me off.
Mar 18, 2009 | 1995 Ford Escort
No more hot air
it is full antifreeze .is the temp gauge at operaiting temp. if not put a t-stat in the car.
Jan 22, 2009 | 2002 Dodge Caravan
Current cut-off
Hi, If the vehicle cuts off and starts right back,it could be the fuel pump relay, defective charging sistem (battery&alternator) can also cause it , If the lights and all the power goes off there is a contact problem ,could be a lose wire, or a defective ignition switch . If it takes some time to start back ,check the fuel delivery sistem,fuel filter ,fuel presure,or clogged injectors.
Dec 08, 2008 | 1997 Mercedes-Benz C-Class
Pitco Frialator SG14 Deep Fryer Logo
41 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
