Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Just purchased a verbatim plug & go 4gig. my machine picks it up bt i get a pop up box asking me to format. when i select the 'format' option it tells me that windows could not format the disk. what's the issue?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
What machine do you have? What version of Windows? The USB flash drive is already formatted. Contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Posted on Oct 25, 2013
2 Suggested Answers
  • 151 Answers
SOURCE: my Verbatim 4gig store and go usb stick in stuck in RAW Format
right click my computer, manage. go to disk management and delete any volumes on the flash and set back to basic disk if it's dynamic. format fat 32
Posted on Mar 15, 2010
Why does my ipad not pick up my emails since BT altered its format?
On any iOS device you can receive mails, if you did setup the account correct. If anything has changed in the account, like from POP to SMTP or if something changed in the account name, or you changed the password, you have to change the settings to.
I think the easiest way is to go to settings, email and change the part BT changed. (what you call format, could be from POP to SMTP)
Or if you have everything about the settings on paper, just delete the BT account and set up a new BT account with the new settings.
Jul 16, 2014 | Apple iPad 2 Wifi 16GB
Hp v250w 32 gb pendrive problem
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
hope this helps
Sep 12, 2012 | Computers & Internet
Verbatim external hard drive says it need formatting before I can use it but that will erase my files that I really need, what can I do
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now
click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or
hope it helps
Apr 14, 2012 | Verbatim USB 20 External 96533 Hard Drive
I have lost the password protect on my store and go and now i can not get it to format back to 32 gb it shows that the stick size is 11.98 gb is there a way to restore it to 32gb ?? i have done a format...
You will have to be the computer administrator to change any values on any of your hard drives
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7 this will also apply to usb drives
right click on your usb drive select properties select sharing then select advanced sharing make sure there is a tick in the share this folder box
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F: D: or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on my computer you should see your 32 GB data right click then select format
another way is to control panel administrive tools computer management disk management right click on your -32 GB data traveller select format
hope this helps you
Sep 10, 2011 | Verbatim Store 'n' Go USB Flash Drive,...
I continually get the pop up asking whether I want to scan & fix the verbatim HD after I have done it a number of times
Hi
You just installed in your computer a USB virus scanner sofrware. Just uninstall this software and this message will disappear every time you plug external HDD.
Regards
Apr 05, 2011 | Verbatim (R) Wallet Drive(TM) USB Portable...
Hi i cannot access my verbatim flash stick. It asks me to format the flash stick but i try to it fails to format can you give me some idea as to fixing this problem pls
I hope your Jump Drive did not get formatted - because all your files would be lost.
You could try this:
Go to "My Computer" and right click on the drive letter for the Verbatim Jump Drive.
Select "Properties"
Click on the "tools" tab and select "check now".
This will check your Jump Drive for problems.
Feb 09, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
My Verbatim 4gig store and go usb stick in stuck in RAW Format
Mar 14, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim 4gig flash drive with broken connector
Not sure what you are asking, is connector broken and you need help putting it back together.
If you don't know how to. Send it to these guys, to get your data files back:
http://www.flashdrivepros.com/
Mar 01, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim 8G USB memory storage stick not working
There could errors in the drive. You should either run a scandisk on it or format it altogether. Either should get it back up and running is it is a genuine device.
1. To check for errors/scandisk right click on the icon of the memory stick, select properties. Under the properties menu look for Error-checking and select check now. The check disk menu pops up. See that Automatically fix file system error box is checked. Then click on start.
2. If you decide to format the memory stick just right click on its icon and select format. But see that you move you vital files from it first else you will loose them.
Sep 04, 2009 | Verbatim VER95327 USB Hard Drive
Format pc card on janome memory craft 300 e
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Jul 09, 2009 | Janome Memory Craft 9500 Computerized...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
93 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
