My solo 1450 laptop monitor went black after I changed my screen resolution and restarted my computer. Will not start (fix) in safe mode or vga mode. Monitor turns and remains black after windows loads.
  • jasoncham79 Oct 08, 2010
    I already tried to hook up a monitor. It still does the same thing.
    Thanks anyway...... any other ideas?
    Master:
  • 388 Answers
Try connecting an external monitor and the change settings back.
Posted on Oct 08, 2010
There is no display on the screen
If you have a display when restartings your computer (the first 10-20 seconds) and then it turns black you can restart your computer, and press f8 during startup, when given options menu choose VGA Mode, windows then starts in minimal graphics mode (safe mode) and you will then have to manually set correct screen resolution that supports your monitor (1024x768 should be safe)
May 03, 2011 | Computers & Internet
I have my monitor connected to my laptop because the laptop screen went out. The monitor has been working fine until the last few days but now when I power on the laptop & monitor, the monitor only...
Please restart the computer and go to safe mode by tapping F8 key once the system is restarting choose Enable VGA Mode (Windows XP)
choose Enable low resolution Video (Windows Vsita / 7).
Change the display settings to slightly lesser than what the monitor can handle and shut down and restart the computer in normal mode.
Jan 03, 2011 | Acer X163W 16" wide format TFT Screen 8...
When I try to use my 17'' Soyo monitor with Windows 7 program the screen turns black and then ''out of range'' wording is all I get on the monitor. I have tried booting in safe mode, set the resolution to...
When you power up the compute press F8 key then enter in :"Enable vga mode" then go to display property and set screen resolution to 1024*768.
Then check .
If still same then enter in safe mode and uninstall graphic driver then start computer normal mode then install graphic driver.
Also in safe mode go to start->run type in run "chkdsk /r" then press ok then press "y" then restart computer then it fix and recovers error on harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 23, 2010 | Soyo Dymond DYLM017A 17" LCD Monitor
No input signal at the monitor when I plug it to a laptop, only when in safe mode I can see the desktop of laptop
When you power up the computer press F8 key then you can see safe mode and other menu enter in "enable VGA mode"
Then go to start ->control panel ->display- settings.
Change screen resolution to 1024*768
Then apply and ok.
then restart then check.
If you still get blank screen then enter in safe mode and uninstall graphic driver from control panel -> add remove program wizard or device manager.
Thanks.
Nov 04, 2009 | Westinghouse L1975NW Monitor
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
I put my Hertz way to high and my monitor isnt working
turns out all i had to do was restart the computer in video mode aka VGD or VGA mode
you get to this by restarting your computer and pressing F8 a bunch of times till you get the safe mode menu and select VGD mode and youll be able to fix ur problem from there
Apr 09, 2009 | Fuji FP-988D 19" Flat Panel LCD Monitor
Monitor went black after changing resolution
Reboot you computer and spam F8 until you get the option to boot in safe mode then choose VGA safe mode or safe mode with network is fine also and change the resolution back
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Screen resolution issue
Use the "F-8" key at boot to get into safe mode. You should then be able to fix the resolution/refresh rate conflict while in safe mode, and get back to normal.
Jan 30, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Blank/Black Screen Asus PC 4G
When you first turn on the computer, start tapping the F8 key to bring up the safe mode screen. You have a very short window in which to press the F8 key before XP loads, so it is possible to miss it. If this happens, just restart it and try it again. Once you are on the safe mode screen, select the enable VGA mode. This will boot your computer to a default 640 x 480 resolution so you can change it back to normal.
Thanks and please don't forget to give this solution a fixya rating.
Jan 26, 2009 | ASUS Eee 4G Notebook
I changed Desktop resolution setting to higher, Monitor went black with "Out of Range" message
please try this:
To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
2. Right-click the desktop, click Properties, and then click Settings.
3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
3. Click Advanced, click Adapter, and then click Change.
4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
6. Click Standard Display Adapter (VGA), and then click Next.
7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
9. Click 256 colors, click Apply, and then restart the computer.
10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
11. Click Device Manager, click View devices by type, and then click Display adapters.
12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
13. Install all updated monitor drivers.
hope it helps!
Nov 02, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
