Question about Dell E173FP 17" LCD Flat Panel Monitor
When you 1st turn on screen comes up for split-second & goes off again. & then power button then flashes on & off as if wanting to come on - but never stays on. Can the board be replaced? screen is fine. where can I get replacement board? ? Serial #CN-OU4931-46633-49N-28ET on back label. Thanks, Keith
  • 11,361 Answers
More likely to have shorted out transistors in the inverter circuits.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
you can also see the video on this web site to see how to take it apart.
Posted on Oct 08, 2010
Need to set just the time on a timex WR100M mens watch
SETTING
  1. First, find the regular time mode by pressing the MODE button until the time (with the date at the top) shows.
  2. Press & hold the SET button until the word ENTER disappears and is replaced by the word TIME. Release that button. You'll notice that at the top of the display, the words SET T1 or SET - T2. This is where you select between setting the 1st time zone or the 2nd time zone. Select between T1 or T2 by pressing the RECALL button or the STOP/RESET button.
  3. Press either the MODE or the START/SPLIT button. You'll notice that whatever is blinking is what you can change. You can make the changes by pressing either the RECALL or the STOP/RESET button. You can change the Seconds, the Hours, the Minutes, the Month, the Date, the Year, and choose between 12 hour (civilian) or 24 hour (military) time. If you keep MODE or START/SPLIT button, you will go through all the things you can change and start again at the beginning. The START/SPLIT button goes through these things forward, and the MODE goes through the backwards, so if you pass something and want to back up, just switch buttons. In the same way, the RECALL changes things by making them larger, and STOP/RESET changes them by making them smaller, so if you accidentally pass the number you're trying to set it to, just switch to the other button and go back.
EXAMPLE OF SETTING THE WATCH Suppose you want to set the hours and the date in the 2nd Time Zone. (Just as an example, but setting any other time or date settings would be the same.)
  1. Press the lower left button on the side (MODE) until you see the date & time.
  2. Press & hold the lower right button on the side (SET) until the word TIME appears on the display, then release it.
  3. If SET T1 is showing, then press & release the upper right button on the side (RECALL) to change it to T2 (because we're wanting to set the 2nd Time Zone we'd leave this unchanged if we wanted to set the 1st time zone, T1.)
  4. Press & release the lower right button on the face (START/SPLIT) twice, skipping the seconds. You should see the hours flashing.
  5. Press & release the upper right button on the side (RECALL) repeatedly until you have the hours position set to what you want it to be. If you pass the hour you want, go to the lower left button on the face (STOP/RESET) and press & release it to back up.
  6. Press & release the lower right button on the face (START/SPLIT) three times, skipping minutes and months, so that the date begins flashing. Press the RECALL button until you have the date you want. (You can go backwards by pressing the STOP/RESET.)
  7. When you're done, and you've set everything you want to, press & release the SET button once to tell the watch you're through setting and to lock those settings in.
Nov 23, 2015 | Timex Ironman Watches
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Press power, buttons light up and thats it
Try pressing the clean cell now button & check pre filter button at the same time hold buttons down at the same time for about 5 seconds with the air cleaner turned of and blue screen lit
Jan 30, 2010 | Kenmore AC2044-1 Air Purifier
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
