Question about Bosch 24 in. SHU43 Built-in Dishwasher
Not draining goes through the cycle but is not draining. I have pulled the filter, cleaned it. Took off the drain hose from the new garbage disposal amd tried to syphin out the water no luck. I have not pulle the dishwasher yet. It just started to do this ands we just had to replace the garbage disposal. Might this have caused the garbage disposal to burn out as well?
  • bjm1224 May 30, 2008
    still not draining. No handy men are willing or able to work on Bosch dishwashers.
  • 868 Answers
Did you remove the plug in your disposal so the dishwasher can drain???
Posted on May 30, 2008
My whirlpool GU2455XTSS1 is not draining. What might be the problem.
first have you installed a new garbage disposal unit in the sink if so does the drain hose for the dishwasher go to the garbage disposal unit? if it does then you may have to remove a knockout tab in the pipe on the garbage disposal. its there because not everyone uses a dishwasher. if that not it check the drain hose for a grease clog get a long wire run it through the hose and try to clear it. Check the filter inside the dishwasher it needs to be clean to suck the water out. Also on the left side of the unit is a housing that the drain hose goes to befor going to the main drain that could be clogged. If the pump has power and runs and hoses are clear im not sure what going on without see it.
Dec 31, 2016 | Whirlpool Dishwashers
Solve will not drain problem
Disconnect the drain hose from your garbage disposal and see if it will drain into a bucket. If it does, how is the flow? Is it just a trickle or a good flow? If it's a good flow, then you have an obstruction in your garbage disposal. If it's a new garbage disposal, did you (or your installer) remember to knock out the plug that's at the end of that drain port???
Jan 09, 2015 | Kenmore Dishwashers
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
Kitchenaid dishwasher wont drain
Allow the current cycle to complete. Draining will occur at the end of the cycle.
Close and latch the door. The dishwasher will not drain if the door is not properly secured.
Press the "Cancel/Drain" button on the dishwasher to start a two-minute drain cycle.
Remove the knockout plug in the disposer outlet of the garbage disposal if the dishwasher drains into the disposal. Turn off the water supply and remove the drain hose from the disposal. Place the tip of a screwdriver on the plug and tap it lightly with a hammer to remove it. Replace the drain hose and turn the water supply on.
Clogged Drain
Run the garbage disposal to empty it and clear the drain if the dishwasher drains into the disposal.
Remove the cover on the air gap on the sink or countertop. Turn the plastic cap counterclockwise to remove it. Remove soil from the inside of the air gap. Replace the plastic cap and cover.
Check the sink. Dishwashers connected to a sink will not drain if the sink drain is clogged. Unclog the sink. Contact a plumber, if needed.
Issues With the Drain Hose
Check to see if there is a loop in the drain hose. The loop cannot be more than 20 inches above the floor. Disconnect the hose and loop it just above the floor. Reconnect the drain hose.
Remove kinks in the drain hose. Always use the new drain hose included with the dishwasher. Do not reuse old hoses.
Check the length of the drain hose. The hose should be less than 12 feet long. Replace with a shorter hose, if needed.
Sep 01, 2012 | KitchenAid KAWS850LE Top Load Washer
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Will not drain.Light flashes for aprox 30 sec then
If you have your user manual for the dishwasher than it will tell you what the code means. Youd garbage disposer is probable plugged up or was changed recently. Try taking off the drain hose that is under you sink that goes to the garbage disposer. Look at the disposer and see if the plug is punched out or not. To punch it out take a screwdriver and hit the end with a hammer inthe hole. It its not pluged, try blowing out the hose backwards with compressed air. Also all dishwashers have some sort of filter system that is accessable inside the machine. Thr taking that off and cleaning it.
Feb 05, 2010 | Hobart Dishwashers
There is a horrible smell inside. We've taken the
cycle the dishwasher, and after it fills with water, dump 6 cups of bleach in there and let it contunue. just before it starts to drain, stop it and let it sit for an hour. restart dishwasher and let it cycle thru.
Oct 10, 2009 | Dishwashers
Won't drain
Make sure the garbage disposal is clear so the water can exit. After that, you may have something caught in the drain hose or check valve. It would require removing the bottom kick plate to gain access to check.
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Dishwasher not draining
I had water at the bottom of my 4 year old plus dishwasher and of course I thought the worst. Did the pump go out, bad impeller, or what else could it be! I started with the easy stuff first and disconnected the drain lines. The drain line runs from the dishwasher to an air gap mounted to my sink, which keeps the drain line from getting an airlock. From the air gap device another larger line runs to the garbage disposal. I used an 8MM wrench to loosen the clamps enough to pull the drain lines off and drained them into a bucket. There really wasn't any resistance to water flow and no real chunks, I was disappointed.
I then took the actual air gap out of the sink by removing a large plastic nut and pulling the devise out from underneath the sink. When I inspected the air gap I saw a wad of hairy, feathery plastic stuff blocking the flow of water. I took the chunk out, reassembled everything and it works like new again.
It is a very easy fix and now even the area under the sink is clean to boot.
Sep 03, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
201 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
