Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
HP lap top computer
I can turn on my laptop and it will begin booting up. I can see it. When I enter my log in and password and press enter the screen will flash and go black. I can hear it processing but no display is there. I plugged in to another monitor and when it gets to the login I can see the display on that screen just not mine. HELP!
    Problem Solver:
  • 19 Answers
Try pressing and holding the fn key while pressing F4 to switch between display modes (it might F5 instead) Wait a few seconds after pressing F4 before pressing it againt to give it a chance to switch. It sounds like you have it set to use and external monitor and you need to toggle back to the built in LCD.
Posted on May 30, 2008
    Scholar:
  • 139 Answers
I think u should try this to see where the prob is from.restart yr system keep presing f8 on yr keyborad to an extend yu will see an advanced startup option then chose the one with vga boot or something then wait n see if it boots normal.
thank u
    Genius:
  • 1,224 Answers
Ok this sounds easy when you were putting in your password in system registry bootup you hit the switch screen to use display video back paralel remove the password and reset the boot process parameters back to default this should relieve your problems
im here if you have any other questions about motherboard bootup
at 9pm arizona U.S.A. time ill be back
My laptop HP ProBook 4510s prompt computer open password befor going to BIOS or OS. And i don't know what is the password? So how can i reset the password to boot the computer.
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps you
Jul 25, 2011 | HEWLETT-PACKARD 574508-001 - Original HP...
Lap top locked wont accept usual password
When you boot up to the log in screen type in administrator as the user to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings or
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
click start control panel user accounts
hope this helps
Jan 13, 2011 | Computers & Internet
I forgot the bios password also i want to update the bios in the laptop my currient version is f 39
when you boot up to the log in screen type in administrator to log in if you cant log in
During the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
or
hope this helps
Dec 04, 2010 | HP Computers & Internet
Cant log on to my laptop
Probably the easiest way to resolve this issue is by following the steps outlined below.
1. Shut down the computer.
2. Turn the computer on and immediately press F8 repeatedly until you get the "Advanced Boot Options" menu.
3. use the down arrow to select "Safe Mode" and press enter.
4. Window is should start with a "Help" window.
5. In the help window there is an underlined "What is System Restore?"
Click on that and "Click to open System Restore"
6. click on that and a new window comes up recommending restoring to a previous state.
7. Click ok and the operating system should restore your computer successfully and reboot into normal mode.
//javaftper
Aug 01, 2010 | Acer Aspire 4520-5141 Notebook
NT LDR IS MISSING IN HP LAP TOP COMPUTER
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root usually C:\ directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "D." This letter may be different on your computer.
    copy D:\i386\ntldr c:\
    copy D:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jan 29, 2010 | HP Pavilion dv6000z Notebook
I Log On To My Lap-top It Passes The Loading Screen Then Gose Dark I Try To Run The Diognostics Disc. It Says I Have A IR Problem I Dont No How To Fix This Plz Help Me Steven. Thank You
If you are using Windows XP, insert your Windows CD in the CD/DVD drive and restart your computer, make sure it boots from the CD. After loading a bunch of things, you should see a screen that tells you to press "R" to go to the recovery screen. Press the R key and when that screen loads, press 1 to log onto Windows. If you are asked for a password, just press the enter key. When you get a C:\Windows prompt, type chkdsk /r and press enter. It will take up to 90 minutes for this to run. When it finishes, type exit, press enter and remove the CD from the drive. Hopefully this will fix your problem.
Jul 30, 2009 | Dell Latitude D600 Notebook
Key board not working
It's a hardware issue,
Maybe RAM or hard drive..
Did you get it used? If so the password was set b4 you purchase it, and will not show up when you type,,,It stays hidden.
Your getting this screen because there is a hardware failure. Fix the problem and you wont need the BIOS password.
Press<esc> to enable startup message, This should give you more info on the problem.
Mar 01, 2009 | HP Pavilion dv9000z Notebook
Cant log on forgot user account password for hp pavilion zd8000
Oh, you must be an Administrator, right? If there is another Administrator account on the PC, it can restore your password through User Account Settings -> Manage Another Account.
If not, I have a complex way. First, restart the PC. When it shows the HP logo when booting up, press the button for Setup (it is shown at the bottom of the screen, and it is F8 on my HP tx2001au).
Now, don't get scared by what appears. It looks a bit complex, but it is very simple and easy.
Navigate using the keyboard. Press the right button to move to the Security section. Here, press Enter on the Administrator Password option. Now enter and confirm a new password and you're done.
See the bottom of the screen for the button for 'Quit Saving Changes' and the computer will reboot. Now, I guess you can enter the new password.
If this doesn't work, see online for ways to reset a password in Vista. There are some softwares to burn to a CD and use.
If it is an XP, I guess there is nothing to do. Just press Ctrl+Alt+Del on the logon screen to see the classic logon screen. Type in the username 'Administrator' without quotation marks and the password blank. Press Enter and enjoy.
Nov 22, 2008 | HP Pavilion dv4000 Notebook
Problem to log in.
Start up in safe mode pressing F8 on boot up and select safe mode. When in the system under administrator there will be option for you to delete the password on your account. Re boot then enter again with no password.
Feb 22, 2007 | Toshiba Satellite M100 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
