Question about Mtd 22" Yard Machine Push Mower
Gas is coming out by air filter.... filter is soaked with gas?
  • Mtd Master
  • 7,482 Answers
Your filter is being soaked with fuel from the carburetor float valve having trash/debris under the seat or jamming the needle valve.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Yardman ym320bc quit running like out of gas. Air filter soaked with gas. If I run with air filter off excessive gas is coming out of carb. How do I fix
MTD makes Yardman. Contact their help desk at mtd.com. I have found them to be helpful even on weekends.
Jul 20, 2014 | Garden
2003 2liter runs fine but it just quits after sitting still for a min or two but starts right back up
I would start with cleaning the idle air control, then would clean the mass air flow. Also check the air filter. I have ran into oil soaked air filters on the Focus.
Jun 27, 2014 | 2003 Ford Focus
Overfilled lawn mower and now it is will not start.and when i try to start it it start for 2or 3 sec and stall out and oil come out of the exhaust.
Overfilled with gas or oil? More in likely you tilted your mower over to far to the air fllter side. The oil has soaked your air filter with oil. Change the airfilter and wipe spark plug off.Once it fires up it will smoke untill it burns the oil out carb. Remember never lean mower to air filter side..Good luck
Aug 17, 2013 | Garden
Husqvarna
Gas filter might not run properly and it must be replace. If it gets bad enough the lawn mower might not turn on and in worse case gasoline could start coming out the air pusher.
Aug 05, 2012 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
I over filled the crank case with oil, as my bike leaks. But my ******* put far too much oil in. I noticed a few days ago that there is oil slowly seeping out under the valve covers, and off the air return...
Hi. I doubt that you have damaged the engine. The only reason the gas milage dropped so drasticcally, is that the air filter must have been soaked in oil. If the filter is soaked in oil, the carburetter will get little or almost no air theough the intake and then your air/fuel mixture is very lean. Make sure to clean the air filter and take it for a drive. Hope this helps
May 25, 2011 | Yamaha TTR 225 Motorcycles
I have a p-3416 poulan saw it is getting spark but the saw still wont start
It's not getting gas. Possible wrong mix oil to gas, but not real likely. Possible sat over the last winter with gas in it and varnished. I'm guessing this is the one, more likely than not. take cover and filter off and clean and bag 'em. pour carb cleaner in the carb and soak overnight. Dump out (carb cleaner and old gas)into a sealable jar or can and fill with straight gas and soak an hour and dump into trash gas/carb cleaner. Use a bicycle pump to blow air into carb to dry it. At most use a computer air can. Then start with the right gas/oil mix, prime it, set the trigger and choke and drop start. (It helps to have the spark plug out during the soak. Then clean it and sandpaper the gap and the magneto area on the flywheel).
Jun 18, 2010 | Garden
How to clean/change air filter on McCulloch 230 saw
These air filters can be soaked in gasoline and dried with great results. Make sure to soak, wring, soak, wring, soak, wring, until all the oil/dirt/chip particles are gone, then wring and let air dry overnight. A moist filter will only collect more debris, so you may roll in papertowel a few minutes prior to install to insure you have gotten all the left over gas out.
Mar 08, 2010 | McCulloch Garden
Air Filter soaked with gas
Clean It with soap and water and afterwards let it dry and put a little bit of motor oil on the filter. You may want to check your petcocks because they may be leaking. Be cautious when you ride with a gas soaked air filter the airbox may catch on fire if the motorcycle backfires which I have experienced in the past.
Jun 26, 2009 | 2004 Honda VT 1100 C2 Shadow Sabre
Carb spittin out fuel when using throttle
change the air filter they spit oil out of the breather tubes that are connected to the rocker boxes when the air filter gets dirty the air pressure lowers on the cleaner side of the carb and then the fuel wants to go to the lower pressure making it come oput of the airfilter side
May 18, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
Mtd 22" Yard Machine Push Mower Logo
713 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
