Question about Tower Aloha Breeze Fan
While plugged in the fan will not turn on. checked other outlets and it is definitely the fan that is the problem. what should i do? i took the back off and dusted the unit as good as possibe.
  • 171 Answers
Quite often a fan will not turn on because it has been run for long periods of time and it wears the brushes in the motor. Some timews you can take it apart and spray wd40 on the shaft behind the blades where it goes in to the motor. Also you can give it a spin manually with your hand while it is pugged in and turned on. I only recommend this as a last result. Do not touch anything else while it is apart and plugged in. Try using a tool with rubber on the end you hold to avoid any potential shock, Thoiugh it is highly unlikely you would get shocked as the blades arer also plastic but better safe than sorry.
Posted on Oct 08, 2010
Unplugged the wine cooler to move for painting. When we re-plugged it in it was not working at all. Took off the back and cleaned out any dust from the fan. All of the wires look like they are in place....
First check your breakers. Sometimes re plugging an item can cause a surge and pop the breaker. Maybe some paint might have gotten in the outlet and preventing a clean contact. If all fails, try plugging in the unit in another outlet to see if the problem lies within the outlet or the wine cooler.
Mar 21, 2011 | Cuisinart CWC-1200 Wine Cooler
Does dimplex model 6902340100 have a fuse, stopped working no fan, no light took back panel off could not find a visable fuse.
My friend just had the same problem. It turned out to be the Remote Control box,( the little box you plug the Fireplace into so you can use the Remote). He just plugged the Fireplace straight into the wall outlet, (without the Remote) and now it works fine.
Oct 19, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Traeger 075 tripping GFI continually
May be too much moisture on the hot rod.
From Traeger:
Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
Jun 19, 2010 | Traeger Industries BBQ075 All-in-One Grill...
Fan willnot turn back on
Is it the same plug? You may have a switched outlet where one is controlled by a switch and the other is constant.
Jun 07, 2010 | Dayton (1UM36) Stand (Pedestal) Fan
FREEZER WORKS...FRIDGE DOESN'T
Hi,...
In that case you need to check this
  • Make sure the refrigerator is plugged in securely
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for current
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet voltage
Good luck !!!
Regards
PCmania
Jul 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fan will not turn on when you plug it in.
that could be the problem.just cut of the plug and attach a new one.
Jun 23, 2009 | Lasko 3720 Floor / Box Fan
Refrigerator no power
Plug some other device into these same outlets or use a volt meter to verify power at the outlet.
You definitely have a house wire problem if the interior light does not come on and the bulb is good.
Also check 120 volts power at the fridge cord where it attaches to the terminal box.
Feb 21, 2009 | GE PSS26SHRSS Side by Side Refrigerator
Replaced window unit - new one won't power up (2nd model)
green light comes on when reset, when try to test goes out, power does not come on at all
Aug 09, 2007 | Samsung AW0503B Air Conditioner
Tower Aloha Breeze Fan Logo
685 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
