Question about Xerox WorkCentre M20i All-In-One Laser Printer
My Xerox Workcentre M20i won't power back on. Have any sugestions?
  • 2072 Answers
SOURCE: xerox workcentre m20i power off
First off try unplugging it and leaving it unpluged for 30 minutes. Not just turned off, but unplugged, then plug it back in and see if it works. There are filter capicitors in the low voltage power supply that sometimes have to sit with power removed for 30 minutes before they discharge and allow the power supply to turn on.
Sounds weird but I have seen it fix a dead machine probably 50 times or more. If that doesn't restart then you will have to replace the power supply. If that is the case let me know and I can tell you where to get it from and ho\w to replace it.
Try leaving it unpluged for 30 minutes. not less than 30 minutes.
Posted on Oct 16, 2008
  • 2072 Answers
SOURCE: xerox workcentre m20i turns off
Sounds like the machine software is corrupted.
Try this first. Turn the machine off, then on back, there is a panel on the back cover with to plastic tabs that will release it. Pop that off and remove both memory sticks.
With the sticks removed, turn the machine on and let it come to ready. Shut the machine off , replace the memories and turn the machine back on, That reloads the machine software cleanly.
If that does not work. Go to Xerox.com, click on support and drivers, enter M10 into the search box, then click on Drivers and Downloads. Once there go to the firmware and download in with the instructions . I think the level is at 3.04 now. follow the instructions to install the firmware.
One of those 2 should resolve your problem.
Posted on Mar 23, 2009
copper7op
  • 30 Answers
SOURCE: How to change the default scan resolution on M20i?
You need to go to the printers webpage from your Web Browser http://192.168.1.100 or something like that. Then, go into Properties tab, and then the Services Dropdown. Under that, go into Email Settings and then Email Setup. Change your DPI to as high as 600dpi, then scroll to the bottom and hit save. You'll be prompted for a password which is either Admin / 1111 or 11111 / x-admin
Posted on May 01, 2009
  • 2072 Answers
SOURCE: Changing print properties shuts down all open programs instantly!
I would first of all Go to the Xerox.com site and go to Drivers and downloads for the M20i and install the newest firmware. I believe the current version is 3.4.
I believe your problem would be resolved in loading the newest machine firmware.
Posted on May 05, 2009
SOURCE: Our Xerox workcentre m20i is
try to unzipp the scanner and try to clean the mirror of the scanner.
Posted on Mar 07, 2011
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
How do you fax papers to someone?
Download the user guide from here: http://www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
Open the table to contents and look for facsimile instructions, and then just follow them.
Mar 11, 2015 | Xerox WorkCentre M20i All-In-One Laser...
Download xerox m20i scanner software
Go to Xerox.com and under drivers and downloads for the M20i , download firmware version 3.02.
And follow the instructions to put the new software onto your printer.
Jun 22, 2011 | Xerox WorkCentre M20i All-In-One Laser...
-Xerox workcentre m20i. -Yesterday turned machine
hi enviro,
so its the supply inside the Xerox is the next to be checked or fuse too..a technician nearest you can help open it.
mastergani
Jan 21, 2011 | Xerox WorkCentre M20 Black and White...
Lost User Manual
Here it is! http://www.fixya.com/search.aspx?_s=xerox+WorkCentre+M20i++manuals
Sep 13, 2009 | Xerox WorkCentre M20i All-In-One Laser...
May 05, 2009 | Xerox M20I Printer
Xerox Workcentre M201 says open heat error
Fuser Error, Open Heat
Error, Heating Error and
Overheat
There is a problem in the
fuser unit.
Unplug the power cord and plug it back in. If the
problem still persists, please call for service.
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox workcentre m20i power off
Oct 16, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
658 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
