Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
Samsung 930b analog to digital input
I bought the dvi-d cable, plugged it into my vid card ( nvidia geforce 7300gt ) and unplugged the analog cable, the monitor wont switch over to digital. what am i doing wrong?
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
Posted on Jun 03, 2008
Where can I download driver .eVGA e-GeForce 7300GT Superclocked 512MB AGP Graphics Card-512-A8-N501-LR
For OEM drivers choose www.nvidia.com or manufacturer drivers www.evga.com Choose Nvidia Geforce 7 series graphics drivers under their download/support. Then choose your operating system and correct bit version 32 or 64.
Nov 16, 2011 | Evga e-GeForce 7300GT 512MB Graphic Card
I have a nVidia Quadro2 MXR/EX video card which works fine on the analog input but when you use the digital input the screen sometimes flashed at startup and then goes blank. If you move the mouse,...
There are a few things that come to mind here. Number one is to try a different and known functioning DVI cable. Maybe see if you can recreate the problem simply by wiggling the dvi cable. If there are any splitters/adapters, remove them and plug the cable straight from the video card to the display. Make sure the display is set to digital input mode. When you are using the digital cable, make sure to completely remove the analog cable. See if this problem happens outside the operating system (such as in the system bios, if it does, this indicates a hardware issue). Finally, the digital input on the monitor could be having an issue, try a different monitor or try this monitor with digital input from another system.
Sep 24, 2011 | HP NVIDIA Quadro2 MXR (32 MB) AGP Graphic...
I don.t find the driver instalation.....:-??
http://www.nvidia.com/Download/index.aspx?lang=en-us
Select : Geforce 7 Series -> 7300 GT and then enter your operating system. Download the driver from that page
Dec 29, 2010 | Chaintech GSA73GT NVIDIA GeForce 7300GT...
Syncmaster 2033 loses signal and blacks out but keeps power. Only way to fix is restart. Windows 7 64bit OS. NVIDIA GeForce 9600 vid card.
I had same problem. Try using another cable, VGA/Digital Video.
My problem was gone if I changed Digital Video to VGA analog.
Aug 12, 2009 | Computers & Internet
I need help setting up the DVI input.
There are two ways to do this.
First and simplest is to simply shutdown the pc, disconnect the analog from the back of your PC and connect the DVI cable to the PC and monitor. When you turn it back on the PC will detect and switch to the DVI.
Second, and better to compare. Connect both sets of cables and go into your display settings, then select advanced options. You should see a GeForce tab in the advanced menu. On that tab there is a multi monitor display setup. Set it to mirror to both screens and apply.
Once it's set switching inputs on the monitor SHOULD work. The problem that makes it a "should" is that both the monitor and the video card have the ablility to sense a connection. So, even with mirroring setup you may have to use the first method as you can't have both connected and operational at the same time.
Give these a try, if you're not sure how to get into the display settings, comment back here with your windows version and I will give you a step by step
Chris
May 02, 2009 | ViewSonic VX924 19" LCD Monitor
Have a new 23 inch samsung monitor that requires res 1920x1080
The problem is the cable connection to the video card.
When using the DVI output of the FX 5500, the maximum screen resolution that you can select is 1280 x 1024.
But, if you use the Analog (VGA) output, the card will support resolutions up to 2048 x 1536, which should be ok.
Apr 23, 2009 | XFX GeForce FX 5500 Graphic Card
Add on PCI-E video card doesn't work
I would check the BIOS To check the boot order preference to see if you can tell the motherboard to Force Starting up with the PCI-E Slot.
If the slot did go bad, most likely you would see the system crash instead of just automatically going back to using the onboard video card.
Mar 16, 2009 | Gateway GT5028 PC Desktop
Dvi port not workink
Change monitor input on nvidia control panel and /or change the input on the onscreen display. mine uses the same thing
Dec 27, 2007 | MSI FX5200-TD128LF GeForce FX 5200, (128...
Monitor Resolution
have you tried the newest drivers for your card?
Nov 30, 2007 | XFX GeForce FX 5200, Graphic Card
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
241 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
